I was told that their is an AC control module in the dash. A shop wants $500 to put in a new one. As I have a 2000 that we are still getting parts from does anyone know where in the dash this control module is?
If it is the vacuum control module/hub it is right behind the trash hook (or ash tray). It has multi-colored vacuum lines coming off it like an octopus. Drop the glove box all the way down, and you will see it off to the left.
Other than that, just the ***** on the panel at the bottom like proSHO said above.
I wouldn't pay anyone $500 to replace anything in the dash. Too easy to do myself.
I paid this shop to fix the ac and they took weeks and replaced the compressor in the front engine with a chinese knock off and the X still does not blow cold. The mechanic claims for another $500 he can replace this magical module in the dash and my AC will blow cold.
I have moved up Montgomery Texas - near conroe - is there a reputable outfit around that can look at my ac?
