glow plug testing??
Old Jan 30, 2020 | 04:35 PM
Bobcatbob's Avatar
Bobcatbob
Originally Posted by Brother Les
Hello Bobcatbob,
Just wondering why you are replying to a threat from 2017?
Because I screwed up & and posted in the "related "
thread that pops up below the current ones.
Off to the "Time out Chair"
Sorry.
Old Jan 30, 2020 | 08:56 PM
kd5zll's Avatar
kd5zll
Old Feb 1, 2020 | 01:51 AM
ajbrown208's Avatar
ajbrown208
Sorry.
I was about to respond too. I had some good input. BACK TO THE FUTURE.
Old Feb 1, 2020 | 05:48 AM
SkySkiJason's Avatar
SkySkiJason
Going under the VC’s is no big deal. I would NOT do anything except GP’s and $0.52 mod.
Shimming the injectors is a controversial ‘bandaid’ for worn injectors. I prefer to just replace injectors when they need it.
There is no reason for compression test. No blow-by = good compression.
GP’s can be changed in about an hour. It will take me longer, because I have to clean the CAC pipes and VC’s while they are out. I use a Little right angle impact for almost every fastener. The back VC bolts and the ones near HVAC box - get 13mm shallow socket, swivel joint and 4” extension. I think a lot of folks get hung up because they want to SEE the bolts. Just use one hand to feel the bolts and the other to guide the socket on - don’t psych yourself out!
Old Feb 1, 2020 | 05:55 AM
SkySkiJason
I use 1/4” drive 10mm deep socket on GP’s. I break them loose with a ratchet, then I use the baby right angle impact and hold the socket on GP at an angle - not fully seated/square - and spinning them out of the holes. Then use a magnet on a stick to lift them out.
If you square the socket on the GP, when you loosen GP the socket/GP get stuck under rocker arm.
johnnyo53
43
Mar 12, 2020 12:15 AM
ranagent
15
Sep 8, 2015 07:37 AM
dev_jhnsn
20
Feb 20, 2015 07:23 AM
bigcountry1009
Aug 29, 2014 03:03 AM
kellerkathleen
Mar 1, 2003 12:55 PM
