One other thing - after all the work on the high pressure oil system - did you run it long enough (and with a few "spirited accelerations") to get the air out?
Again thanks for the help and I will be more than happy to Rep all you guys.
Replacement of ICP, IPR screen, and Pigtail were the last maintenance actions I performed prior to starting this thread. There was no difference from old to new.
I pruchased the ICP and pigtail from Diesel parts direct as suggested by Diesel Tech Ron. The IPR came from Accurate Diesel. Lastly, I have run the truck an estimated 30 mins...got her up to 176 degrees. Not gonna lie...Im a little affraid to give too much throttle bc the way she's running.
Mark, Randy, and Rusty...Rep's given! Thank for all the input! Guys like you really bring maintenance efforts on these trucks back in focus after hours of foggy frustration!
That could be FICM related, but you originally posted that the FICM was good on both sides, so I left that one alone - besides it is next to impossible for the average owner to troubleshoot all aspects of the FICM.
You could post the MPower, VPower, and LPower voltages at KOEO, cranking, low and high idle and maybe something will show up. Do it w/ a cold engine and a hot engine.
After that, installing a known-good FICM (if you have one available) would be recommended.
The reason for focusing on the ICP is that the values are just not correct. Definitely need to resolve that problem. IMO get it resolved first, but others may feel differently.
Roger that! Programming the Scan Gauge II, and gathering values are first on the list.
I recently replaced the injectors on my truck and when I reinstalled the FICM 1 pin got bent and the truck idled rough/lacked power. A kill test on the injectors indicated #2 was dead. Removed the FICM and found a bent pin. Straightened it out and all is good
Here's what I got after programing the scan gauge II to read ICPV:
KOEO (cold and no injector chatter)
ICP 3300 then resets to 0
ICPV 3.87 (bad!)
IPR 14.9
FMP 48
FLP 11.5-12
Sync yes
Good point! I will be checking the pins first thing Wednesday! Thx for the info!
