two problems with 81 f100
Old Sep 1, 2003 | 05:08 PM
hermangarza's Avatar
hermangarza
so far i have two problems one is my usual trans oil leak(last weekend i replaced filter and seal and new trans oil. now, when i start the truck and shift to drive i have to wait 10 seconds until i feel it go into drive gear? any suggestions.
Old Sep 1, 2003 | 10:11 PM
Ford_Six's Avatar
Ford_Six
Is it a c4, c5, or c6? What fluid did you put in it, and is it full? How does the fluid look, is it aerated at all?
Old Sep 2, 2003 | 03:53 PM
hermangarza
c6 and the fluid i not sure starts with the D and i think it has a 3 somewhere one becuase it took me a while to find which one it was until i found the manual where my dad had written it. Has anyone had this problem beforewith a delay?
Old Sep 2, 2003 | 09:02 PM
1987LTDmasta's Avatar
1987LTDmasta
dexronIII/Mercon is what you added. that works, but i noticed harsher shifts with it on my c-6. i believe for the c-series trannies your supposed to use F-type trans fluid.
it shouldnt take a long pause like that even with Mercon, check your trans fluid level. you may be a quart low.
Old Sep 2, 2003 | 09:25 PM
hermangarza
should i drain all and place f-type fluid in it?
Old Sep 3, 2003 | 12:41 AM
Ford_Six's Avatar
Ford_Six
NO! The c6 from 77-up used Mercon/Dexron. If you use type F, you will destroy the transmission.
Old Sep 3, 2003 | 03:55 PM
hermangarza
now im confused
Old Sep 3, 2003 | 10:09 PM
STUDENT's Avatar
STUDENT
I had a similar delay in my c6. It got worse and worse. In the winter it took 2-3 minutes to go in gear. A rebuild fixed it up though. I believe my delay was caused by worn out seals not building pressure like it should to make it shift. Once mine went in to gear it was fine. Reverse always worked fine, just going in forward gear that was a problem.
Old Sep 3, 2003 | 10:31 PM
hermangarza
thats the problem i have but a rebuild right now is put of the question
Old Sep 3, 2003 | 11:08 PM
STUDENT's Avatar
STUDENT
For a daily driver, yeah it is a pain. But I did my own rebuild. Got the parts for $100.00 and a hayes techbook for rebuilding trannies at Autozone. Never did one before in my life.
Old Sep 4, 2003 | 03:21 PM
hermangarza
maybe once i put the doors on ill rebuild it but it sure is a pain in the *** to wait
Nhull97
Sep 14, 2014 08:13 PM
johnnys69highboy
Jan 31, 2012 07:31 PM
D.Wolf
Nov 2, 2009 03:13 PM
mlowe
Jan 2, 2007 09:21 AM
desertstorm-007
Aerostar
Aug 26, 2003 03:31 PM
