To much camper?
Old Apr 8, 2017 | 09:20 PM
kansas gary's Avatar
kansas gary
To much camper?
The wife has been looking at some new 5th wheel campers. The one she really like is the Cedar Creek (Silverback edition) 33 IK.
GVWR-14067lbs.
Hitch weight- 2067lbs.
UVW-10880lbs.
Exterior length-36'11"
Exterior height-12'9"
My truck- 2016 6.7LTurbo Diesel F-250SRW Crew Cab 4x4
Axle Ratio- 3.55
GCWR-23,500 lbs.
Maximum loaded trailer weight ratings---15,100 lbs.
Do I have enough truck for this camper or should we be looking at a smaller camper?
Old Apr 8, 2017 | 11:11 PM
bikerman5345's Avatar
bikerman5345
You should be fine with that rig. I tow my 2017 sandpiper 389rd and it's 42' and 12900 empty. 15500 gross. My truck pulls it and stops it with out an issue. I have a 2017 F250 with airbags and the camper package.
Old Apr 9, 2017 | 08:04 AM
senix's Avatar
senix
That is no problem figure around 2800 lbs for the king pin wt. Well within reason for the truck.
Well below the GCVWR of the truck.
Old Apr 9, 2017 | 08:45 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Other than it staring at you in the mirror, you will not even know it is back there. I would/could pull that trailer with my 17 year old 7.3, you will not have any problems.
Old Apr 9, 2017 | 03:03 PM
Irelands child's Avatar
Irelands child
The truck will have no problem hauling that 5er. Be aware that you will most likely exceed the @#$& yellow sticker on the 'B' pillar though. If that is of no concern, go for it - I did
Old Apr 9, 2017 | 10:32 PM
whooboy's Avatar
whooboy
You drive around the beautiful country of ours and you will see thousands if not tens of thousands of 5th wheels that size or larger being pulled by F-250, Chevy 2500, and Ram 2500 series trucks. I have never heard of anyone having problems because of the weight of these trailers. Nor have I ever heard of anyone being stopped by any law enforcement authority to check to see if you are within the weight limits of your truck. You have a lot of excess capability there. Use it. Enjoy it. We have a Cedar Creek RV Owners Club where many of the trailers are in the 36 to 40 foot range being pulled by trucks like yours.
Old Apr 14, 2017 | 07:04 AM
ssunit1's Avatar
ssunit1
My 5er is just under 14K and I pull it with no issues. My max is 15100 just like yours. No issues.
Favored
Apr 18, 2019 07:27 AM
mattmattn
Dec 7, 2018 11:37 AM
tstolar
23
Mar 4, 2013 01:32 PM
cwilson285
All Things Towing
Mar 7, 2005 08:05 AM
SDice
Aug 17, 2003 03:31 PM
