Aggressive cruise control
Old Apr 8, 2017 | 07:27 PM
Richard Aarts's Avatar
Richard Aarts
I'm asking this question for my cousin who has a 2015 lariat with the 5.0 and he says that when using cruise it's very aggressive on the acceleration using the resume. It stays in second gear til 60 mph. Does anyone else have this? Is there a way to adjust it so it's an easy steady acceleration?
thanks
Old Apr 8, 2017 | 07:38 PM
srb1194's Avatar
srb1194
Well I have a 17 with the 10 speed. Mine is fairly aggressive on resuming speed but not to the degree you're describing.
Old Apr 8, 2017 | 10:01 PM
GlueGuy's Avatar
GlueGuy
If you're more than 10 MPH below the set limit, most cruise controls are relatively aggressive to get to the set speed.
What I typically do is accelerate at my pace until I am within 3 to 5 MPH below the set speed (or at "about" the set speed), and then hit resume.
Old Apr 9, 2017 | 06:36 AM
Gary Lewis's Avatar
Gary Lewis
I agree on all points.
But, if his is holding 2nd then maybe he has it in Sport mode?
Old Apr 9, 2017 | 10:04 AM
GlueGuy's Avatar
GlueGuy
Never thought of that; or the truck thinks it is sport mode (i.e. uncommanded).
Old Apr 9, 2017 | 03:56 PM
GABAR's Avatar
GABAR
thanks
I`m sure the aggressiveness has a lot to do with how slow he was going before the " RESUME " button is pressed and like the other poster said, if the transmission is in the SPORT mode, the acceleration might be more harsh compared to the non SPORT mode.
Old Apr 10, 2017 | 05:22 PM
TJReams's Avatar
TJReams
Every vehicle I have ever owned, since 1978, has had an "aggressive" cruise control. If you are going above 40-45 and hit resume for a speed above 95-70 mph it will get there as fast as it can. Because that is the speed you selected, that is where it wants to be. If that's to quick for you then get within 5 mph accelerating at a speed that is comfortable for you then hit resume.
Old Apr 12, 2017 | 07:06 PM
RigTrash601's Avatar
RigTrash601
Look at page 224 in your owners manual, the truck has different behaviors,
if you have the distance indicator set @ 1 bar, cruising @ 62 MPH the truck acts like it's in sport mode, At the same speed with the max following distance it states the vehicle dynamic behavior is "Comfort mode". I assume (yeah, I know) that has some of the cause for the aggressive behavior.....? Not completely sure and I haven't tested it personally, or I could just apply to braking behavior...
Old Apr 13, 2017 | 03:42 PM
TJReams's Avatar
TJReams
Only the 502A option has that if he has 500, or 501 As I do we do not have adaptive cruise control.
volwing1
All Things Towing
16
Sep 21, 2017 10:31 AM
jfralph
6.7L Power Stroke Diesel
Sep 12, 2016 10:30 AM
reelnut
Jun 18, 2012 06:53 PM
dyoungen
Feb 23, 2012 10:48 PM
Crownie
Aug 15, 2004 12:44 AM
