I have a 1986 Bronco with the AOD trans in it. The question I have is, what is the difference between the 2WD and 4WD AOD's?? Can I use a 2WD AOD and put my transfer case behind it?? Thank you for any information you guys can give me.
You cannot use a 2WD AOD with a 4WD as the output shaft and extension housing are different lengths.
