ignition timing
Old Nov 29, 2001 | 05:59 PM
canabait's Avatar
canabait
ignition timing
Is it possible to advance the timing on my 1993 F-150, 5.0 without b
Old Nov 29, 2001 | 11:15 PM
PAUL_2's Avatar
PAUL_2
ignition timing
Sure , But why do you want to ? You wont gain anything in mileage or performance . Computer controlled engines today dont respond to the same kinds of alterations non computer controlled engines experienced in the past .
Old Dec 4, 2001 | 01:49 AM
HippieCustoms's Avatar
HippieCustoms
ignition timing
Go to www.corral.net. this is a mostly mustang forum, but have many ideas and performance related discusions that will answer your question. I would like to share my opinion though. If the computer was so inclined to ignore your adjustments, then why have a base line timing setpoint. why pull the spout and set the timing to ten to start if the computer was going to do all the work. Slight adv of the distributor will give greater total advance to the ignition mechanically. Now if you advance it too far, the engine will knock from predetonation, and the knock sensor will retard it. don't make it that far and you will reap the benefits of alittle adv in the hp and mileage dept.
Old Dec 4, 2001 | 08:10 AM
slowsix's Avatar
slowsix
ignition timing
