Would like to see any photos of quick connects for an external in bed tank that is all removable. I know about replacing the stock tank etc. but I don't think I want to do that right now. I'm pondering a setup that will fit below the bed rails that I can use with my diamond back cover but I want a complete removable system so I can still have the full use of my bed.
It depends on how you install your tank. If you end up using some rigid pipe, be sure to put a union in there so you can pull that apart. But if you are planning on removing this tank often then keep it simple! The RDS kit come with a valve that screws into the bottom of the aux tank, the valve has a barbed fitting for 5/16" fuel hose that comes with the kit. The 5/16" hose goes to a T that you cut into the existing fill hose of your vehicle.
When you want to remove the tank, simply loosen up the hose clamp for the 5/16 by the valve, pull hose off, and remove tank. Then I'd plug the hose so no contaminates get in it.
