Double honk!!
Old Apr 9, 2017 | 07:28 PM
klassic's Avatar
klassic
Originally Posted by saskowner
My concern with the double honk is having it happen in a nice quiet campground as I am backing into my spot. I usually hop out a couple of times to see how things are going. I am considering putting a relay in the horn wire and then controlling the relay with an upfitter switch. I'm sure there will be times when I forget to turn it back on right away but hopefully I can live with that.
Gary
Just disable it with FORScan...much easier
It's worth the price of the BT adapter.
Old Apr 9, 2017 | 07:35 PM
Sleepyguy's Avatar
Sleepyguy
Safety feature my ****. Pretty sure this is the only push button vehicle with an alarm when you exit with truck running.
You all need to get on Fords as about this problem. Forescan can cause other problems it seems but then again not sure if it's people meddling or what is the cause.
Give Ford feedback on the issue
Old Apr 9, 2017 | 07:52 PM
bridge's Avatar
bridge
Sick 'n Tired
I disabled mine using ForScan...but I'm not surprised Ford is directing Dealers not to disable it. It is a safety feature along with the 30 min automatic shut-down. Since push to start and hybrid vehicles first started coming out there have been several cases where people parked their Hybrid in their garage, put it in park, and just left it on. Once the battery depleted the hybrid would kick on the combustion engine and carbon monoxide leaked into the house and killed the occupants. I realize ours aren't Hybrid's but, is following industry recommendations for push to start and hybrid vehicles. Once a few more people perish I'm sure NHTSA will get a law passed that requires all PTS and Hybrids to have similar safety features that cannot be disabled.
Old Apr 9, 2017 | 09:28 PM
Sleepyguy's Avatar
Sleepyguy
I hate safety not because it is meant to save lives but because it's taken to extremes.
Nothing personal just object totally to the whole idea that is considered safety. It's a diesel they are not silent and they are smelly. If you don't know your vehicle is running maybe should switch to electric. They are silent no fumes and will likely explode like Samsung phones eventually.
Old Apr 9, 2017 | 10:11 PM
BII Plow Truck's Avatar
BII Plow Truck
The word "Safety" is very broad. It's more security, the terms overlap in the legal world. The main reasons are two fold.....you walk away from your truck and it gets stolen, or even worse you and your wife go someplace but only you get out with the key in your pocket and your wife drives the truck away and she gets stranded someplace (in a bad part of town).
Old Apr 9, 2017 | 10:14 PM
Ryanf73's Avatar
Ryanf73
Why can't Ford just do a chime and make it unable to shift out of park? Horn is a little overkill..
Old Apr 9, 2017 | 10:21 PM
bridge's Avatar
bridge
Sick 'n Tired
Probably because you have to exit the truck and shut the door resulting in the key outside the truck. If you're outside the truck you can't hear a chime.
You can use ForScan to enable Secure Idle, which would prevent the truck from shifting into drive if the key isn't in the truck.
Old Apr 9, 2017 | 10:25 PM
Ryanf73's Avatar
Ryanf73
The chime would be for the person that is with you (wife) that thinks there are going to drive off without a fab.
Old Apr 10, 2017 | 09:30 AM
railrode1's Avatar
railrode1
What we all need is a specific contact to to the right person at Ford. Then everyone complains to the same contact about this issue being obnoxious Overkill. A simple chirp would get the point across to the driver just as well. My wife's button start Volvo doesn't do this crap.
Old Apr 10, 2017 | 09:37 AM
fordmantpw's Avatar
fordmantpw
That's not what the double honk is for.
Old Apr 10, 2017 | 10:42 AM
Ryanf73's Avatar
Ryanf73
Your right. . Its for making everyone mad
Old Apr 10, 2017 | 11:33 AM
ForeverFixing's Avatar
ForeverFixing
I agree with the double honk, it would seem they could rout it to a secondary reminder that was more of a small toot if it has to meet a safety requirement. Everyone within a block does not need the information.
Old Apr 11, 2017 | 09:32 PM
  #28
mtnguy's Avatar
mtnguy
I have been just leaving the fob on the seat when I get out.......only in a relatively safe area, of course.
Old Apr 11, 2017 | 10:09 PM
  #29
Sleepyguy's Avatar
Sleepyguy
Email them or twitter or Instagram
https://owner.ford.com/contact-us.html
white 66
1947 and Older Ford Trucks
Apr 19, 2018 11:34 PM
chad77
May 3, 2016 06:35 AM
GLEB
Nov 17, 2011 05:38 PM
PSNut
Dec 13, 2005 01:49 PM
