1966 Mercury original truck? VIN decode
The engine codes are sort of interesting. In 1965 they list them as follows
Gasoline
1 = Mercury 8 Cyl
4 = Ford 8 Cyl
5 = Mercury 6 Cyl
6 = Ford 6 Cyl
Diesel
7 = Mercury 6 Cyl
8 = Ford 6 Cyl
SQ = 6 Cyl. 300 C.I.D. (L.D.) - Service Code CEGY
I assume a Mercury engine just has a Mercury valve cover on an otherwise Ford engine, but just a hunch.
JJ = Rangoon Red paint. Looks like a hint of it still near the warranty plate.
Chad
Gasoline
1 = Mercury 8 Cyl
4 = Ford 8 Cyl
5 = Mercury 6 Cyl
6 = Ford 6 Cyl
Diesel
7 = Mercury 6 Cyl
8 = Ford 6 Cyl
Chad
Chad: I could be wrong (and I'm sure someone will tell me so if that's the case), but the only vintage FOMOCO engine's I've seen with Mercury on them were the early to mid sixties FE Roundtop, the FE Pentroof ones, and some Y blocks.......but I have never seen a 300 with a Mercury valve cover?
Mercury FE "Roundtops"
FE Pentroof
Mercury Y block
James
FE Pentroof
Mercury Y block
James
Yah, I really like the Pentroof ones with the lightning bolts, I have two sets here, but one is actually rusted through on a portion that would have been vertical ON the engine, but I think they came off an engine that had been laying out in a pasture somewhere for a LONG time. Still, cool garage art, or perhaps I will cut out the script & lightning bolts and weld them into some Windsor VC's and put them on my 351W roller motor, just to see how many people we can confuse
1965 Mercury f100
Hello this is Jonathan I have a 1965 Mercury f100 stepside pickup. It has the front mercury letters on the grill also has the badges on the front fenders that read Mercury. And the keys read made in Ontario Canada. The plates (warranty plate) on drivers door reads made in Ontario Canada by the Ford motor company. But the title says it’s a Ford. So my question is is it a Ford or clone Mercury? Or how could I find out?
In 1966 both the Ford and Mercury trucks used the same Warranty Plate - that's not it in the pictures. If that is in the location of the Warranty Plate then I'd saw, judging by the fact that tag has been fooled with - that something would be amiss.
Look a little more on the Latch face of the left front door and see if you find the warranty plate. A drawing of what it should look like below.
Chad
Chad
Here's how the warranty plate decodes. If you look up a few at post #16 you can see the M100 on that tag which indicates a Mercury, as well as the 5 as the first character on line #1 which decodes to a Mercury engine.
4991014L-217924A 15 UR 3.54:1
F100 114.8 5,000
SS-3M/D
4 - Ford 8 cylinder gasoline
99 - Styleside Pickup
10 - 100 Series
14 - 114.8 inch wheelbase
L - Left Hand Drive
217924 - 1965 model year
A - 6,000 lbs or less GVWR
15 - Red crush vinyl and red ladder pattern woven plastic - 81B Custom Cab
UR - Wimbledon White and Rangoon Red tu-tone paint
3.54:1 - rear axle ratio
F100 - Ford 100 Series
114.8 - wheelbase in inches
5,000 - lbs. gross vehicle weight rating
SS - 8 cyl. 352 C.I.D.
3-M/D - 3-speed medium duty transmission
Here's the legend of gasoline engine decodes for 1965
1 = Mercury 8 cyl.
4 = Ford 8 cyl.
5 = Mercury 6 cyl.
6 = Ford 6 cyl.
Chad
F100 114.8 5,000
SS-3M/D
10 - 100 Series
L - Left Hand Drive
1 = Mercury 8 cyl.
4 = Ford 8 cyl.
5 = Mercury 6 cyl.
6 = Ford 6 cyl.
Chad
#30
1965 Mercury VIN decode.
99 = Styleside Pickup. If this was a Flareside pickup, the body style would be 83, not 99.
10 = 100 Series.
14 = 114" Wheelbase.
L = Left Hand Drive.
217924 = 1965 Numerical Sequence of Assembly, the trucks specific serial number.
A = 3,600-5,600 lbs. GVWR range.
15 = Red Crush Vinyl & Red Ladder Pattern Woven Plastic / 81 = 81B Custom Cab.
UR: U = Honey Gold / R = Red.
Dana 44 or 60.2 Rear Axle / 3.54-1 / Limited Slip / 3,300 lbs. Axle Capacity.
F100.
114.8" Wheelbase.
5,000 lbs. Gross Vehicle Weight Rating.
SS = 352 2V.
Ford type 3.03 3 Speed Manual all Synchromesh Transmission.
