The Perfect Suspension?
Old Apr 13, 2017 | 07:28 PM
Kingkong0192's Avatar
Kingkong0192
Originally Posted by tshrager
And that's needed why?
Originally Posted by cowmilker08
Are you mocking the setup or just trying to be funny? I can't tell.
No. Not mocking. Just asking why he didn't go one step further in sort of a joking manner.
I'm just saying if you're taking the time to 4 link a truck you probably have the time/knowledge to slap a disc brake setup on it as well.
Old Apr 14, 2017 | 06:52 AM
tshrager's Avatar
tshrager
It's a budget thing. Unless we have unlimited budgets, the line needs to be drawn somewhere. This particular dually axle had just been gone through with fresh brakes and the works. The dually "kits" to convert to disc brakes are awfully expensive. So for me, the benfit of shelling out well north of 2k to essentially be able to change brake pads easier just isn't worth it. Maybe if everything else is done to the truck and this is the last thing that needs done. Maybe. By then I'd probably shell out the 3k for a 550 Dana 135 and go big.
Old Oct 22, 2018 | 08:38 PM
RJ Cleelan's Avatar
RJ Cleelan
Looking for a smooth suspension!
06 F250 Powerstroke 6.0 | 4WD Crew Cab | Wheels: 20x10 Tires: 33x10
If anyone out there knows of a smooth suspension kit for my Powerstroke, let me know! As of know, the truck rides HORRIBLE! I can be going down a smooth road, road over an ant and feel the dang thing! Don't even get me started on those classic bumpy roads...
No, but for real, someone please direct me towards a kit. Bought the truck used and the lift that's on it now was already on it, so I have no clue what it is (height or anything, I attached a pic). I'm thinking 4' maybe... It also has airbags, so I don't know if that's a main factor or what. Should I let some of the air out a bit? How much should I keep in when I'm not hauling anything?
Thanks in advance everyone!
Old Oct 23, 2018 | 08:13 AM
knottyrope's Avatar
knottyrope
do a chalk test to check tire pressure
My 95 rides very stiff. Tire pressure does help a lot with feeling road bumps. I went with 50 PSI and I doesn't feel squishy in corners but your tires, load and feel are different than mine.
Also what tires do you have? some tires are just plain stiff no matter what you do.
Old Oct 25, 2018 | 10:58 AM
RJ Cleelan's Avatar
RJ Cleelan
The tires I am running are some cheap Cooper Discover’s. 275/65/20 they can hold 80PSI. How much air should I be keeping in them do you think?
Old Oct 26, 2018 | 08:53 AM
knottyrope's Avatar
knottyrope
those are similar in load range to mine, start at 50 and see the chalk wear
how to
https://itstillruns.com/chalk-tires-6948382.html
Robert6401
Jul 25, 2020 04:49 AM
Kingkong0192
Nov 6, 2016 02:04 PM
BoulderLionX
Oct 3, 2010 12:40 AM
Shad's EX
Apr 10, 2006 12:27 AM
dashboardetc
Jul 21, 2003 06:49 AM
