1995 f150 shifter stuck in 3rd gear
  #256
Old 04-11-2017, 10:13 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
Originally Posted by sandymane
we will make sure it is going to work first before rtv... you dont need fluid to see if it is going to work. Do you want me to tell you what to do? and you can do it tonight or tomorrow and let me know and then we can rtv
Yeah we can do that
  #257
Old 04-11-2017, 10:14 PM
sandymane's Avatar
sandymane
sandymane is offline
That fluid is for mercon which is what we use. You need 7.6 qts. Did you put the electrical connection in?
  #258
Old 04-11-2017, 10:16 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
7.6 quarts total guess I better go buy more lol this is only 4 quarts. I put the electrical connection back on I haven't hooked it back up to the truck
  #259
Old 04-11-2017, 10:21 PM
sandymane's Avatar
sandymane
That transmission is thirsty. It is really low. Usually it leaks out where the rubber plugs have failed when the truck is running. Remember you said it didnt leak. That could be because the fluid was so low IF the plugs are fatigued. Plus you had no fluid on the cover when you pulled it.
  #260
Old 04-11-2017, 10:23 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
The rubber plugs look and feel nice and study
  #261
Old 04-11-2017, 10:28 PM
sandymane's Avatar
sandymane
Sounds like you want to just use them? No RTV ?
  #262
Old 04-11-2017, 10:29 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
i mean whichever way is most effective
  #263
madpogue's Avatar
madpogue
madpogue is offline
Is the gasser ZF some really different animal? The ZF5 behind the diesel takes only about half that much fluid.
  #264
Old 04-11-2017, 11:03 PM
sandymane's Avatar
sandymane
Thank you very much. I got punchy I think
Ksanglem
Thanks to madpogue it is now 7.6 PINTS so you are ok. 7.6 qts would have probably created a mess like I had.
  #265
Old 04-11-2017, 11:06 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
Ksanglem
ok thank you is there anything we have to mix to it or just pour the fluid in while the top is off
  #266
Old 04-11-2017, 11:22 PM
sandymane's Avatar
sandymane
OK we will RTV them to save your tranny and at the least having you do this get into the tranny again when it starts marking its territory.
OR Whatever you want to do.
In the meantime you can make sure and tighten the elect, connection. You don't have to hook it up now as it is coming off when the new fluid goes in.
See if you can get the cover to start lowering like the forks are going into the sliders. You can very gently wiggle and help get the cover to go flush with the tranny. If it goes on you can put in about 4 cover bolts and snug them and work the shifter with the clutch in. DON'T start the truck. A couple of moves and take it off and do the fluid. At that point if you want to rtv let me know.
  #267
Old 04-11-2017, 11:28 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
well Its super dark out right now so I think it will be best to wait til the morning to go ahead and try this step
  #268
sandymane's Avatar
sandymane
just pour it in. I would see if the cover fits first you dont have to bolt it and try it. Just see if it goes on so we know.
  #269
Old 04-11-2017, 11:38 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
Looks like it goes on what ya think
  #270
Old 04-11-2017, 11:44 PM
sandymane's Avatar
sandymane
Is it flush to the transmission?
Quick Reply: 1995 f150 shifter stuck in 3rd gear
