1949 brake drums
Old Apr 6, 2017 | 04:19 PM
Jafo56's Avatar
Jafo56
1949 brake drums
Is there any trick on getting off the front and rear brake drums on my f-4 ?..... once the screws are removed in the back does the drum just come off? ....and how about the front ones?
Old Apr 6, 2017 | 04:38 PM
harleymsn's Avatar
harleymsn
First off, check to see if the drums still have the screws into the hub. Second, on the back there are cam adjusters that need to be turned to back the shoes away from the drums. If you made sure those are taken care of, you might have to just beat on them a bit.
Old Apr 6, 2017 | 04:48 PM
Jafo56's Avatar
Jafo56
Ok got ya... thanks joe that's my next project
Old Apr 6, 2017 | 06:37 PM
harleymsn's Avatar
harleymsn
It's been a few years since I did the brakes on Edith, and I lost several thousand pictures when a hard drive crashed. If I remember correctly, you have to remove the front hubs and drums together, as they are bolted together from the back. On the rear drums, there are 3 flathead screws on the face of the drum screwed into the hub. The cams on the rear of the backing plates turn inward to back the shoes off.
Old Apr 6, 2017 | 06:49 PM
raytasch's Avatar
raytasch
Believe Nothing
Originally Posted by harleymsn
If I remember correctly, you have to remove the front hubs and drums together, as they are bolted together from the back. .
Yes, they come off together and there is a good chance you will have to back the adjustments off to get the drums off the shoes.
low 66
Oct 18, 2010 06:35 AM
fordguy038
Aug 15, 2007 05:23 PM
mr1950M-68
Mar 29, 2007 04:58 PM
'95 Splash 4.0V6
Dec 30, 2003 07:15 AM
luke_trash
Jun 30, 2003 10:07 PM
