brake drums
Old Oct 16, 2010 | 11:55 AM
low 66's Avatar
low 66
brake drums
I'm trying to get my front drums off. But can't. Do I have to remove the bearings. To get it off or is their anything else I can do tried everything
Old Oct 16, 2010 | 01:27 PM
CropDusterMan's Avatar
CropDusterMan
The little brake assembly holding pins may have come loose from the rear of the drum...it throws the brake assembly inside out of wack and makes it a real bear to get off...it took me a while of working to get mine free.
Old Oct 16, 2010 | 01:29 PM
Broomfieldbum's Avatar
Broomfieldbum
I found that someone had riveted my right front drum on. I had to grind off the rivet and then the drum removed. I have also seen the brakes being adjusted out too far causing this symptom. The drums are not attached with the front bearings.
Old Oct 17, 2010 | 08:48 PM
jhooch's Avatar
jhooch
If they are original the studs are probably "swedged", mating the drum to the hub. In this case, yes, removing the bearings is the easiest way.
Old Oct 18, 2010 | 06:35 AM
low 66's Avatar
low 66
I ended up removing the spindle nut and hub bearings came rite off that way couldn't get the drum off any other way
