Coolant temp and EOT
Old Apr 7, 2017 | 10:03 AM
Amicus's Avatar
Amicus
Should be getting a Bluetooth obd connector today and will monitor on torque pro to veryfi the temps.
Old Apr 7, 2017 | 10:05 AM
WatsonR's Avatar
WatsonR
I wouldn't be doing any towing and don't let it get to 250*... It's time to take action!
Old Apr 7, 2017 | 10:11 AM
jetjockey99's Avatar
jetjockey99
Get the universal coolant out of your engine ASAP. I would do the chemical flush and refill with an EC-1 antifreeze, then, wait a couple of weeks, while monitoring temps, then do another distilled water flush and replace the oil cooler. It will cost a little more to do that way but you can't run with water only and antifreeze is cheaper than another oil cooler.
Old Apr 7, 2017 | 01:31 PM
Amicus's Avatar
Amicus
coolant was replaced/flushed the following morning. I think that's what I will be doing is just monitor for a couple of weeks.
Thanks everyone.
Gilbert
Old Apr 7, 2017 | 02:01 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You didn't answer all my questions either.... do you have studs? Are you running the tuner withOUT studs? What coolant did you use when you ran out? What are you using NOW for coolant? You came on here asking for help but we need info before anyone can help you.
Old Apr 7, 2017 | 02:11 PM
Amicus's Avatar
Amicus
Im not studded. Yes, running tunes with out studs. Not sure of the emergency coolant. Just that is said for all makes and models. I was in a bind and had to take what my Friend brought me. He called me before and read the lable to me and I thought it work for the moment. Had it flushed by the dealer the following morning They also used and additive. Im assuming that they used the correct coolant.
Thanks
Old Apr 7, 2017 | 02:17 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Thank you for all the information! You DO realize that running a performance tune without studs may lift your heads that have torque to yield (STOCK FORD) bolts holding the heads down? That would result into pouring coolant into the oil system.
Just warning you of the consequences of running a tuner without having head studs.... just be careful with your right foot on the go pedal.
JamesMcMn
Oct 17, 2016 10:47 PM
ves83
Aug 15, 2014 12:08 PM
tpull3
Jan 1, 2012 06:05 PM
Acftmaintainer
May 3, 2011 10:38 AM
Whitey Ford
17
Jul 17, 2010 11:14 PM
