1 speed washer pump
Old Apr 6, 2017 | 08:56 AM
cbquinn66's Avatar
cbquinn66
1 speed washer pump
Looking for the 1 speed washer pump number for my 1966 f100 that mounts on driver side fender.
Old Apr 6, 2017 | 09:11 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Windshield wipers themselves came with either a single or two speed wiper motor (LO-HI). But, that has nothing to do with the washer pump. Same pump for both types of wiper motors. Makes it easy, at least.
C1AZ-17664-C - Windshield Washer Pump - For switch-actuated washer.
Chad
Old Apr 6, 2017 | 11:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C1AZ-17664-C - Windshield Washer Pump - For switch-actuated washer / Reproduced
Applications: 1965 F100/350 / 1966 F100/250 (2WD) / 1966 F100 4WD / 1966/67 Econoline / 1967 F100/350.
1961/64 Galaxie / 1965 Mustang with 2 speed wipers / 1965/66 Mustang with single speed wipers / 1965/67 Thunderbird / 1966/67 Bronco.
Old Apr 6, 2017 | 03:54 PM
cbquinn66's Avatar
cbquinn66
I don't have 3 holes like that on my fender.I only have 2 holes next to my washer bag? is that possible?The 2 hole are about 2 1/5" apart
Old Apr 6, 2017 | 04:02 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I just measured the distance here and the two lower holes are 2 23/32" apart roughly. 3rd hole is just North of the forward most lower hole.
I was thinking they might have just left one screw out, but I'm not getting a measure of 2 1/5" between any of these.
Chad
Old Apr 6, 2017 | 04:10 PM
cbquinn66's Avatar
cbquinn66
I know that there was a pump with only 2 holes and had 2 single wires.Was wondering if that could of been used instead of other.Sorry holes are2 1/2" straight across from each other within a couple of inches to bag bracket
Old Apr 6, 2017 | 04:41 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The pump that ND and I are giving the number and applications for (thanks ND) takes its ground from the chassis ground and has a single hot 12V wire running to it that is activated by either the pushbutton or wiper switch, depending.
This is an NOS one, but it looks just like my used one, only shinier. On the left mount is a small grounding strap for the ground itself - since the thing is otherwise somewhat insulated from ground by the rubber mounting grommets.
Chad
NavigateNate
Jan 6, 2018 08:45 AM
cbquinn66
Apr 22, 2017 05:03 PM
peter sipp
Apr 30, 2014 04:53 PM
jmslmartinez
May 29, 2011 12:55 AM
matt2491
Mar 9, 2008 01:30 PM
