Vacuum Leak
Old Dec 22, 2017 | 04:46 PM
System's Avatar
System
Prolocutor
Yep, just had my vacuum booster replaced under warranty yesterday. So far, the issue is cured. Previously they changed the vacuum hose assembly which did not cure the issue so this time they went deeper. The check valve must be intradgrul to the booster itself.
Old Jan 17, 2018 | 02:27 PM
Slanted's Avatar
Slanted
How long is the vacuum expected to stay in the brake booster system under normal conditions? On my previous vehicle (a Subaru) it would remain for days, but after a week or two if I didn't drive it would bleed off and I'd have a hard pedal at start. I assumed this was normal. On my brand new 2017 F-250 (Gas), pedal is always rock hard after sitting over night, and sometimes noticeably firm after an 8 hour work day, and to me that doesn't seem normal. What's the expected performance?
-Adam
Old Jan 17, 2018 | 02:31 PM
System's Avatar
System
Prolocutor
Adam, I'm not sure there is a normal amount of time listed anywhere, but it should last longer than 24 hours for sure. Now that my booster has been replaced, I've gone 3-4 days and still had a nice soft pedal on startup. I haven't let the truck set long enough to test it longer than that. Mine started out like yours and in the end would loose it after 15-20 minutes. Then, every once in a while, it would last days again. The internal check valve must be at fault.
Old Jan 17, 2018 | 08:56 PM
mooch91's Avatar
mooch91
I wonder if it's more noticeable with the push-button start which requires the brake pedal be depressed to start? I don't think I put my foot on the brake with any of my key start vehicles while starting, so I don't know that I would have noticed it on them otherwise.
Old Jan 18, 2018 | 08:38 AM
Slanted's Avatar
Slanted
I drove stick shift vehicles for so long that pressing the brake to start is a permanent habit for me. As a result I notice this every time even though I have key start in my XLT. Leaving work yesterday rock hard pedal. Time to call the dealer about both this and the 34 gallon tank fuel gauge issue.
Old Jan 18, 2018 | 08:48 AM
System's Avatar
System
Prolocutor
If they tell you it's normal, keep pushing. It took me talking to the owner and the service manager to get my booster swapped. The tech and service writers kept telling me it was completely normal.
Old Feb 14, 2018 | 09:27 AM
System's Avatar
System
Prolocutor
Well, less than two months later.... an old friend has returned.... I won't fight the fight again...
Old Feb 14, 2018 | 10:45 AM
Martin6's Avatar
Martin6
Well that's a bummer. Mine has the vacuum leak also and was holding out taking it to Ford until, or if, more issues presented themselves. Now I think I'll just live with it.
Old Feb 14, 2018 | 10:48 AM
System's Avatar
System
Prolocutor
I have an antifreeze leak and will be trying a new dealer. I might mention it to them and see what they say...
Old Feb 14, 2018 | 11:18 AM
f350ktm's Avatar
f350ktm
Sorry to hear the vacuum issue has come back.
Hopefully the new dealer will be able to trace it down.
Was the coolant leak easy to identify?
Old Feb 14, 2018 | 11:57 AM
System's Avatar
System
Prolocutor
I haven't brought it in for that yet but it seems from the other thread about it, that it's a common thing... Got a call in now and will post up when the truck goes in...
Old Feb 14, 2018 | 12:23 PM
f350ktm's Avatar
f350ktm
Yea, I've been watching the other thread for information also.
I thought I smelt coolant on mine last week but have not been able to smell it again yet.
Old Feb 15, 2018 | 09:55 AM
  #28
tony m 6.7's Avatar
tony m 6.7
Mine had a very small antifreeze leak, about 1 quart or 2 over 7k miles. Turned out to be a freeze plug in the head on the passenger side. I would see small drips on the driveway, turns out it would find it's way down along the track bar.
Old Feb 15, 2018 | 10:01 AM
  #29
System's Avatar
System
Prolocutor
Thanks for the info. Will mention it to them. Seems that freeze plugs and secondary water pump are the two causes posted here...
Old Feb 20, 2018 | 07:21 AM
  #30
System's Avatar
System
Prolocutor
New dealers says they found the antifreeze leak. The degas bottle had a bad seal so it was a leak in the form of steam. This is why I could smell it but not see any drips. New one going in today. Will see if that cures it.
They also said that there is indeed a check valve for the master cylinder. Funny, dealer one said no such animal and replaced the whole master. Anyways, it's on national back order which may indicate they are changing a lot of them out in the wild. Will report back when that one comes in and get's swapped...
