Help!
Old Apr 4, 2017 | 09:28 PM
Colin Seaberg's Avatar
Colin Seaberg
Help!
I have got a 81' Ford F-150 300 6 and my gas guage will bounce around a couple times a week, Last week it said I had 1/2 a tank, then to 1/4 of a tank, now without putting any gas in it, it says I have 3/4 of a tank, can someone tell me what is going on here because I am stumped
Thanks!
Colin
Old Apr 5, 2017 | 09:47 AM
1986F150six's Avatar
1986F150six
Welcome to the forum, Colin Seaberg!
Likely, it is the in-tank sending unit. There is a single wire which connects to the sender and is attached at the top of the fuel tank. If you can loosen the wire and touch it to the frame [electrical ground] with the key in the "on" position, the needle should swing all the way to full. If it does, that indicates that the gauge and associated wiring is okay. That would point to the sending unit being defective.
Old Apr 5, 2017 | 01:54 PM
Gary Lewis's Avatar
Gary Lewis
Yes, welcome to FTE!
Don't forget the Instrument Cluster Voltage Regulator. It serves the fuel, water temp, and oil pressure gauges, so if it is going bad all three will bounce around. Are they?
Old Apr 13, 2017 | 03:58 PM
Colin Seaberg
No only the gas gauge is bouncing around.
Old Apr 13, 2017 | 04:40 PM
FuzzFace2's Avatar
FuzzFace2
Then I would say it is the sending unit.
I don't think the float fell off as it would not move the gauge at all so I think it is the sweep arm to the wire the issue.
You did not say what size tank or where this tank is located but know when you go to replace it if it is the side 16 gal tank, the size for a short bed, some places list the same sender for the 16 gal and the 19 gal (long bed) and this is wrong, 2 different senders.
Also IIRC the 19 gal side tank and the 19 gal rear tank (long bed duel tanks) use 2 different senders between them.
I think I got my 16 gal (short bed side tank) from AAA.com on line but would need to check that to make sure.
Dave ----
Old Apr 20, 2017 | 03:56 PM
Colin Seaberg
Thanks for the help!
It is a long bed and 2 tanks, the front tank when switched does not show how much gas is in it but when I flip it to the rear it shows but like I mentioned before bounces around, it stays at half a tank now, on saturday I will fill her up completely and see how she reacts.
Old Apr 20, 2017 | 04:24 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
My rear tank sending unit is shot and shows "E" when switched but supplies fuel. The midship tank's sender works fine. I calculate how many miles i get out of the midship tank and apply it to the rear tank. Regardless, i fill both of them when it's time for a fill-up. How many miles do you average per tank of fuel ?
Old Apr 20, 2017 | 04:41 PM
WhatsAChevy?
Excuse my lack of manners
Welcome to FTE and the Bullnose forum ! Blue Ox is more sensitive and she reminded me of my short coming.
Old Apr 21, 2017 | 08:53 AM
FuzzFace2's Avatar
FuzzFace2
Ok long bed with 2- 19 gal tanks
Now we figured that rear tank sender is on it's way out the way it is bouncing all over the place.
Now for that front tank, does it supply fuel but just does not read or not fuel & no read?
Switch to the rear tank and take the wires off the sender.
If it is like mine and I think others as well, 1 wire is a ground and the other the gauge wire.
With a test light you can check each wire at the plug, gauge wire should blink the light the other no blink.
If you use that no blink wire as a ground to test the blink wire you will know each wire is good.
If no blink or ground you will need to trace back the wires to see were the issue is and fix it.
To check the gauge use a jumper from blink wire to ground. The gauge should go to full.
If the above checks out good then the side tank sender is bad also.
Now for no blink and tracing so trucks IIRC the gauge goes thru the fuel switch valve, others the dash switch.
I would also think if the gauge is bad you may not get the blinking but you do have the other tanks the reads ok sometimes so I am thinking it is either a bad switch/valve or sender.
good luck
Dave ----
Old Apr 21, 2017 | 10:06 AM
Colin Seaberg
Yes it still sends gas, just does not read how much it is in the front, and the front tank has a huge dent and is a 10 gallon tank, the back reads 20 (weird I know, but the guy I bought it from was trying to make it a "Race truck")
Old Apr 21, 2017 | 11:45 AM
FuzzFace2's Avatar
FuzzFace2
Does the dent make the side tank a 10 gal?
I ask because a stock long bedside tank should be 19 gal, the short bed 16 gal.
You can not put a 19 gel tank in place of a 16 gal as I tried and would not fit.
On the rear I guess if bone dry you could get 20 gal and that is close to the stock 19 gal as not to worry.
On the side tank if you can get to the wires pull them off and test like I posted and see if the gauge works when grounded.
Dave ----
Old Apr 24, 2017 | 12:07 PM
Colin Seaberg
Yes I believe it makes it 10 because when I took it to go get gas i filled it up and it read 10 gallons.
Old Apr 24, 2017 | 12:29 PM
WhatsAChevy?
Originally They should have been approx. 19 gal. each with a slight reserve. If the original midship tank is only holding 10 gal, that must be one heck of a dent (more like a brutal beating with a 5 lb. sledge). Have you peeked up under the truck to see if maybe the tank was swapped out ? (for what I don't know). If it was beaten into 10 gal. submission, I'd be concerned with it's original mounting situation. I'd also be concerned that the dents might me occluding the sender arm or float itself causing it not to move. Any pics ?
Old May 2, 2017 | 10:36 AM
Colin Seaberg
I will try to get some soon, after I am done with my work, all I know is that it looks like this truck was trying to go over some rocks and maybe the truck went up and landed on a rock is what it looks like.
mudslingur
Jun 25, 2007 01:29 AM
dylan1952
Feb 6, 2007 11:18 PM
tlb
Feb 22, 2005 05:44 PM
customfoam
Electrical Systems/Wiring
Feb 25, 2004 08:15 PM
monroemike
May 30, 2002 01:48 PM
