I need help with my gas guage, the needle stays on empty when i start the truck, but when i disconnect the tank switch it goes all the way to full, can somebody give me procedures to check it or to try something, both tanks do the same thing , empty and full when disconnecting the switch.
i have already changed the cluster and it did the same thing , does this mean that somewere before the dual switch the wires are grounding? both tanks read the same.
EDIT:
it stays on empty when ignition is on and goes to full when tank selector is disconected
You don't say what year or model truck you have. At one time, back in the 70's the fuel gauge would read full with low resistance (10 ohms) and empty with high resistance (73 ohms). Somewhere in time Ford changed the way their gauges worked. I don't know which year it was. I do know that on a 93 F150 that low resistance (22.5 ohms) makes the gauge ready empty and high resistance (145 ohms) makes the gauge read full. This is the opposite of the earlier gauges. Assuming you have one of the later type I would say your sending units are both bad since unhooking them essentially makes the resistance go high (open circuit). This would be easy to check with an ohmmeter. Unplug the fuel sending unit and measure the resistance. If it is low (22.5 approximately) then your gauges are reading what is being sent to them correctly. This means your sending units are bad.
Take the wire off the sending unit at the tank, and ground it. The guage should swing full scale one way. Take the wire off ground and let it hang in the air. The guage will swing the other way full scale. This will tell you if your wiring and guage are working.
