Charging issues
Old Apr 6, 2017 | 09:20 AM
Gary Lewis's Avatar
Gary Lewis
Oh, the test must be done running. You are checking the output of the alternator.
Old Apr 6, 2017 | 09:29 AM
sgauvry's Avatar
sgauvry
OK. Let me see if I have this right.
1. Have the regulator plug disconnected from the regulator.
2. Jumper A and F.
3. Start the vehicle.
4. Connect the probes to prospective battery terminals.
Does that cover it?
It's raining buckets outside today so I can't do it today. Hopefully tomorrow.
Thanks!!
Old Apr 6, 2017 | 09:51 AM
Gary Lewis's Avatar
Gary Lewis
Yes, that's it, although you won't want to run it very long since the voltage may go fairly high w/o a regulator and you don't want to damage anything. So, I would disconnect the regulator, connect the voltmeter, start it, and then jumper A to F briefly while watching the voltmeter.
But, it might be easier to install the new regulator and, hopefully, the problem will go away. However, if you are wanting to return the regulator then you shouldn't plug it in or they probably won't take it back.
Old Apr 6, 2017 | 10:09 AM
sgauvry's Avatar
sgauvry
Understood!
Thanks a bunch, Gary!!
Old Apr 7, 2017 | 08:56 AM
sgauvry's Avatar
sgauvry
Received the new regulator yesterday. I put it is. Voltmeter readings are as follows:
Readings as follows:
650 = 14.58
1000 = 14.61
1500 = 14.60
2000 = 14.60
2500 = 13.32 and continuous dropping of volts (not sure if this is good or bad)
Have not yet performed the tests Gary recommends. Will do so when it's sunny out (pretty cold outside today) for the sake of learning as well to ensure things are as they should be.
Thanks to Vinny and Gary for all of the help!
Old Apr 7, 2017 | 09:02 AM
Gary Lewis's Avatar
Gary Lewis
Well, it is not good that the voltage is dropping, although something may have changed that I'm not thinking about. If it were me I'd monitor the voltage and not do those tests if the voltage comes back to 14+ volts any time you are much above idle. But, if the voltage comes down below that, and especially if it is headed back to 12.8 then I'd run those tests as something is wrong.
Old Apr 7, 2017 | 09:51 AM
kr98664's Avatar
kr98664
Yes and no, actually. This could be normal as the battery takes a charge. The regulator senses this and decreases the charging voltage to match.
I always like to stress the importance of fully charging the battery before electrical troubleshooting. In the real world, though, I'm as guilty as the next guy. Typically the only time anybody ever checks the alternator output is when the charging system is misbehaving, the battery is already low, and you're stranded or nearly so. Basically, you can do some ballpark troubleshooting with a low battery, but for the most accurate results, charge the battery first.
Also, if not comfortable doing the detailed electrical tests on the alternator and regulator, you can take them to any good parts store and have them bench tested. This will rule out everything but external faults such as wiring and bad grounds.
FWIW, I've always consider the alternator and regulator as one unit that just happens to be separated by about two feet. I'm probably wasting my money, but if one component has failed, I change them as a set.
Old Apr 7, 2017 | 09:58 AM
kr98664's Avatar
kr98664
Clarification please. Was 13.32v as low as the reading dropped? Or did it keep dropping, and if so, how low?
Have you run a ground jumper to the base of the voltage regulator? A bad ground here is a common problem and can cause all sorts of charging issues.
Old Apr 7, 2017 | 03:36 PM
sgauvry's Avatar
sgauvry
Thanks for your replies!
The voltage keeps dropping rapidly when at 2,000 rpms.
Yes, there is a good ground from the base of the regulator to the negative battery terminal.
sgauvry's Avatar
sgauvry
I agree, Gary. I’ll monitor it for a time and see what develops. Thanks!!
Xenthrax
16
Jan 27, 2014 08:15 PM
55FordLover
26
Mar 26, 2012 10:45 AM
RANGER589
May 20, 2011 08:40 AM
johncardi
Jul 5, 2009 11:11 PM
rustyoldford
Electrical Systems/Wiring
Apr 3, 2007 03:52 AM
