Lake Orion, MI--AE Request
Happy Saturday Guys,
Got my OBII to USB plug in yesterday and ran the truck with FORScan. Everything seems to be perfect from what I can tell.
At idle (operating temp):
IPR = 14.45%
ICP = 5000.00 kPa = 725 PSI
Everything picked up just fine when I was accelerating. Still stalled on me going down the road but re-started fine. I am convinced there is a short somewhere or the CPS that I got is not working properly.
Got a quite a few codes, see below:
--- PCM P1280: ICP Failure (Probably need to clear codes and see if this comes back)
--- OTC B1203: Fuel sender circuit short to battery. Module: Overhead Trip Computer
--- GEM B1318: Battery voltage low
--- GEM P1876: Transfer Case 2-Wheel Drive Solenoid Circuit Open or Short to Ground
--- GEM P1865: Transmission Transfer Case Contact Plate Power Short to
Ground
--- GEM B148: Brake On/Off Switch circuit failure
I’m sure some of these are just because I have been disconnecting the batteries and also needed a jump from trying to start it to many times.
I also noticed my OD light is flashing. It comes and goes which is odd. Need to look into that more.
For all those that offered there AE I greatly appreciate it. I feel with the FORScan I can figure something out.
Any more insight is always helpful. Thank you!
-Kyle
IPR = 14.45%
Ground
-Kyle
Hey Fellas,
Well from what I can tell the truck is up and running great. Turns out the CPS from Ford did the trick. Lesson learned to not get a "aftermarket" CPS. At least she has a new IPR & ICP although it was a bit pricey. Thank you for all the support and willingness to come out my way to give a hand.
Have a great Easter weekend!
-Kyle
-Kyle
mcguirehg
01-11-2014 11:04 AM
beeper212
34
10-24-2013 12:27 PM
big bad diesel
07-28-2007 06:48 PM
