ZF6 Manual transmission fluid
So it's been a few years since this discussion has taken place, and the ZF6 is not as popular or common of a transmission as it used to be.
The Haynes manual calls for Mercon V in the ZF6 manual transmission. The specifications and ratings for automotive fluids are constantly changing. Ford may have recommended Mercon V ATF back in 2002, but in 2017 the fluid has obviously changed a bit.
Personally I think Merc-V ATF is way too thin of a fluid for the ZF6 transmission. In the past few days I flushed my ZF6 with cheap walmart Merc-V and now I'm hunting for an optimal fluid or mixture of fluids for the transmission.
Years ago there was a thread about a board member's 'special blend' of fluids and additives and numerous people had tried the mixture and reported it to work well. I found that thread and most of the oils and additives are no longer available for purchase or hard to find because the labels have changed.
What would you recommend for a ZF6 manual transmission? I'm going to try adding lucas oil stabilizer to my Merc-V fluid today.
Anyway I ran Royal purple synchomax or the Pennzoil version I'm not sure of the name of it but both are basically the same as GMs sychromesh fluid or Fords synthetic manual transmission fluid. It was just slightly thicker than the atf and helped quieten down the gear rollover noise mine made with the single mass flywheel. You can't go too thick because it needs to be pumped through the cooler.
I ran those fluids from 50,000 miles til I traded it at 300,000.
Correct - I suggest that you contact a Ford Dealership for their recommendation based upon your model/year/VIN. That would help to ensure that you have the correct fluid for the application.
I have been working as a outside contractor at the ZF plant in Marimar FL. The Facility manager is very knowledgeable I will ask him tomorrow. Just hold tight to then. I will try and post what he says during the day.
