Possible causes Faulty Diesel Particulate Filter (DPF) Pressure Sensor Diesel Particulate Filter (DPF) Pressure Sensor harness is open or shorted Diesel Particulate Filter (DPF) Pressure Sensor circuit poor electrical connection Diesel particulate filter pressure sensor connecting hose is loose, cracked, or missing Diesel particulate filter pressure sensor connecting hose port is cracked or broken Excessive amount of soot or ash in the diesel particulate filter
Faulty Diesel Particulate Filter (DPF) Pressure Sensor Diesel Particulate Filter (DPF) Pressure Sensor harness is open or shorted Diesel Particulate Filter (DPF) Pressure Sensor circuit poor electrical connection Corrosion or poor mating terminals and wiring Leaks in the diesel particulate filter pressure sensor connecting hose
