Code 29
Old Apr 4, 2017 | 12:16 AM
TuggyBoat's Avatar
TuggyBoat
I'll start by checking the vacuum lines and check the sensor, I will probably just replace the sensor to be on the safe side. I have a diagnostic check sheet for by the cruise control. Is it recommended to change out the tps and the mlps at a certain milage?
Old Apr 4, 2017 | 08:21 AM
subford's Avatar
subford
No, I have not heard anyone say to do that at a certain milage.
Old Apr 5, 2017 | 10:27 PM
TuggyBoat's Avatar
TuggyBoat
Ok, I'll just concentrate on fixing the egr and the cruise control, that will keep me busy, thanks again subford.
Old May 25, 2018 | 06:38 PM
TRSCobra's Avatar
TRSCobra
Any updates? I have a 1993 F250 7.5L E40D with the same 1992 ECM and getting a code 31 and 62 with a CEL. Did some troubleshooting and replaced the ECM with a reman unit a year or so ago and the problem went away.
Well a few months ago the truck just started stalling at random times, and the transmission would take forever to shift into second, with a harsh shift. No cel.
I ran the codes anyway and got a 29. Threw a VSS in because the internet said so and the code went away for a few weeks. Now its doing the hard late shifting again and occasionally stalling. Still. No. CEL. But getting codes 29, 31 and 62. I reset the codes, took it for a quick drive, and same codes came up.
Bought an EVP, but the old one tests the same so I'm wary about putting that in.
I'm getting tired of this!
Old May 25, 2018 | 06:51 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
31 EVP - (O, R, M) EVP signal is/was out of range
EVR - (O, R, M) EVP signal is/was low
PFE - (O, R, M) PFE signal is/was low
Code 62 see here.(Being in the diesel section doesn't matter.Same info applies.)
E40D: The Importance Of A Clean Trans Harness.
VSS code could be PSOM or wiring issue between VSS and PSOM.
FX4-350
35
Jan 11, 2014 05:46 PM
strokinout
28
Oct 25, 2013 09:59 AM
IJRoorda
Jul 21, 2011 08:18 AM
Selkirk
1978 - 1996 Big Bronco
May 16, 2009 10:30 PM
Whou4
Aug 19, 2004 12:44 AM
