1978 - 1996 Big Bronco
rebuilding a 351w efi engine
Old Sep 1, 2003 | 01:06 AM
COBRAjrb's Avatar
COBRAjrb
Question rebuilding a 351w efi engine
hey, i got a 88 351w efi bronco and im thinking on rebuilding the engine and i was curious how much $$ it would usually cost.
Old Sep 1, 2003 | 01:23 AM
88DesertBronco's Avatar
88DesertBronco
I had my 88 351 long-block rebuilt. It really depends on if you do any work or a shop does all the work. For example, are you going to pull the engine? A long-block rebuild is around $1000. It can be more if you want "perfomance parts". See summit racing for pistons, cams, etc. While surfing the web, I found this company,
http://www.ford-auto-and-parts.com/r...988-parts.html
They have a 7 year/70,000 mile warranty on the rebuilt engine. I would like to see any machine shop even come close. My engine had 6 months/6,000 miles. I would sure liked to have had a 7 year warranty. If the shop removes/replaces the motor, maybe $800-$1000 for that.
Old Sep 1, 2003 | 01:01 PM
COBRAjrb's Avatar
COBRAjrb
cool yea im probally going to pull the engine i will check that web site out that looks like a good deal. right on thanks for the info 88desertbronco
Old Sep 2, 2003 | 03:58 AM
anomaly's Avatar
anomaly
It says carb for fuel delivery on that link
Old Sep 2, 2003 | 09:22 AM
Kemicalburns's Avatar
Kemicalburns
You can try this link to, looks similar.
http://www.ford-motors-engines.com/index.html
later
Old Sep 2, 2003 | 10:47 AM
88DesertBronco
I would imagine that some of the info on the engines is boiler plate. I would not think they would sell you something that didn't work for FI. I would also think that you still have to take parts off your old engine and put on the new. Alternator, starter, maybe fuel injectors, intake manifold, etc.
Old Sep 2, 2003 | 10:53 AM
Kemicalburns
to swap over to a 351 from a 302 you would need a new oilpan, distributor, lower intake manifold (reuse upper 302 plenum) mounting brackets from a 351 for your alt,ac, ps . You will also need the correct dampener and flywheel 28oz and get your exhaust moved up a little to bolt to the manifolds. you would also need an ecu from a rig that had a 351 and same tranny you are using now.
here is a link that helps explain this stuff,
http://www.fast351.com/tech/351w.htm
MICHAELHARPER11
20
Oct 4, 2015 01:13 PM
quickieR
Sep 19, 2015 10:03 PM
hitecdan
26
Oct 20, 2014 10:57 PM
Motorhead351
WTB - Parts & other
Jul 7, 2014 10:12 PM
allford86
Engine Swaps
Aug 22, 2004 11:36 AM
