6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Stutters at 45 mph
Old Mar 30, 2017 | 05:39 PM
mr. red's Avatar
mr. red
Stutters at 45 mph
When accelerating truck stutters and looses power at 45 mph.What could be causing this issue? 2010 f250 super duty
Old Mar 31, 2017 | 07:33 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Have you done anything to your truck lately?
Possibilities range from dirty fuel filters, a plugged up DPF, dirty air filter.
Old Apr 1, 2017 | 08:35 AM
mr. red's Avatar
mr. red
Truck has new air filter, I'll check the fuel filter, does this truck have the pick-up screens in the fuel tank? How do i check to tell if the DPF is plugged?
Old Apr 1, 2017 | 08:48 AM
CampSpringsJohn
The truck has 2 fuel filters, one on top of the motor, the other on the frame rail under the drivers door. Use Motorcraft. If you've never changed them, they probably need it. Also, you MUST turn the key on but don't start it at least 6 times to get the air out of the system after you change the filters. Turn the key on, listen for the pump to run, after about 30 seconds or so, it'll shut off. Turn the key off and turn it back on, do the same thing. Repeat it at least 6 times, 10 would be better. Failure to do this will put air into the injection system, and then you'll have a whole lot of fun trying to get it to start.
As for a plugged DPF, one sign of an issue is if the truck goes into regen a lot more than it should. Also, if you have a monitor, you can set it to read the Exhaust Back Pressure. If it reads much over what the turbo boost is, that may be a problem.
Can you pop the hood and grab the rod that you see among the turbos? With the truck shut off, you should be able to move it back and forth. It will have a little resistance, but it's suppose to move. Or, when you turn the ignition on, you should be able to see that rod move back and forth one time before you start it.
Old Apr 2, 2017 | 12:23 AM
mr. red's Avatar
mr. red
Great info on the filters, and you nailed it with the regen thing it does it all the time. crappy gas mileage also. Thanks for the help.
StanleyZ
6.7L Power Stroke Diesel
15
Jun 11, 2019 10:44 AM
tompc59
Nov 11, 2012 07:30 PM
countrykid_86
Aug 13, 2011 04:21 AM
fishyfishy
Nov 7, 2010 06:19 AM
roushcm
Jan 31, 2010 07:51 PM
