1978 - 1996 Big Bronco
Inline 6 hot starting
Old Aug 31, 2003 | 11:27 PM
horsepotatoes's Avatar
horsepotatoes
I drove my Bronco to the store when I came out it acted like the battery was dead. I came back 3 hours later and it fired right up. Any ideas what it could be? I was thinking maybe the voltage regulator? Thanks
Old Aug 31, 2003 | 11:44 PM
DW2455's Avatar
DW2455
you just need to check out a few things, your starter could be giving up to the heat, clean and check your ground, and you may need to replace the pos. cable going from the solenoid to the starter, they may look good on the out side but as they get old, and repeated times of gotting extreamly hot the wires on the inside will start to break down especialy when hot, and they wont transfer the amperage required, just some thing to check, i'm shure mor of the guys will jump in later with more ideas. Good luck! DW
Old Sep 6, 2003 | 11:24 PM
horsepotatoes
Thanks, I'm going to get it tested and see if it's bad. What are symptoms of a bad voltage regulator then?
Old Sep 6, 2003 | 11:33 PM
DW2455's Avatar
DW2455
a bad voltage reg. can either over charge or under charge the battery. DW
