Trans HELP!
Old Aug 31, 2003 | 10:21 PM
Cool1996's Avatar
Cool1996
Question Trans HELP!
I Have a 1996 f-150 302 5-speed. i want to change trans fluid. how to? what is the capacity PLEEEEEEEEASE help me
-Justin
_____________________
If You Don't Drive A Ford, Why Not???
Old Sep 1, 2003 | 02:24 PM
Native Gearhead's Avatar
Native Gearhead
Trans HELP!
That depends on what kind of transmission, and what kind of change your doing. Is it auto or manual?
Generally speaking, in an automatic, a fluid/filter change without a flush or draining the TC will require anywhere from 5-7 quarts. If its a complete flush, in general, the capacity if 14-16 quarts.
Manual transmissions are usually measured in pints, although I'm not sure of total capacity, maybe 4-8 pints?
Old Sep 1, 2003 | 05:27 PM
Cool1996's Avatar
Cool1996
Trans HELP!
It Is a manual, what type of fluid should i use
Old Sep 1, 2003 | 07:18 PM
Ponyracer's Avatar
Ponyracer
Trans HELP!
If it is a M5OD
Total capacity is 7.6 pints of mercon ATF
If it is a gas ZF 5 speed
mercon multipurpose automatic transmission fluid 3.4 guarts
if a diesel ZF 5 speed
synthetic mercon multipurpose auto trans fluid 3.4 quarts
Quoted directly from the 1996 Ford CD repair manual
Even though it is more expensive, I believe that you can use the synthetic in either of the ZF 5 speeds.
You most likly have the M5OD
there should be a drain plug on the bottom of the transmission and a fill plug on the drivers side halfway up. If I remember right, they are both either 7/8 or 15/16 size bolts. While your at it make sure a check the three rubber plugs for the shifter housing on the top of the trans for leaking. If they are they will need to be replaced soon as they can leak out trans fluid and ruin the trans before you know it.
justin25taylor
Jun 9, 2010 08:37 PM
Justin Time
Jul 6, 2008 10:29 PM
Justin G
Escape & Escape Hybrid
Aug 31, 2006 10:42 PM
bronco30
New Member Introductions
Oct 8, 2004 09:58 PM
Cool1996
13
Nov 8, 2003 12:38 AM
