Sponsored by: Real Truck
2004 6.0 stalling
Old Mar 27, 2017 | 01:40 PM
shawn24's Avatar
shawn24
2004 6.0 stalling
I have a 2004 6.0 133000 miles will be driving down the road will start to hesitate and looses powers and shuts off. wont start back up but if you wait 10 to 15 minutes will start up and run just fine. wont do it again. Just had new head studs put in new head gasket and egr delete 2 new injectors put in
Old Mar 27, 2017 | 01:54 PM
DarkStarMedia's Avatar
DarkStarMedia
You might want to check in the 6.0 forum... But I will say that the first thing they will ask is for data.
Do you have torquPro or forscan? when it dies you are going to want FCIM voltage, ICP, IPR and likely a few other stuff. If you don't have a proper scan tool, get one... they are required for diagnosing the diesels. Cheap too, you can get set for less than $40
richard
Old Mar 27, 2017 | 02:03 PM
shawn24's Avatar
shawn24
I have a scan guage 2 fcim voltage is good icp and ipr are good no check engine lights at all just started doing this
Old Mar 27, 2017 | 03:52 PM
Bumblebee04's Avatar
Bumblebee04
Did you have HPOP stc upgraded, dummy plugs, & standpipes done while in there? Sounds like you have a hpop leak when it gets hot. You'll need to check numbers while cranking when the problem rears its head. Same goes with a hpo air test, do it when its hot.
Edit: also are you using oem oil filter & cap? Aftermarket filter & cap are no good
Donwan
Jun 12, 2018 11:42 AM
Jeff Gara
Mar 9, 2017 03:51 PM
DieselDowdy
Sep 15, 2013 07:42 AM
cottagecoatings
May 9, 2013 03:53 PM
Bmac65459
Jul 21, 2011 06:25 AM
