Kubota's Modifications thread, w/ chit chat
#167
Sorry I never got back to reply last month, busy holidays and a new puppy keeping me busy! Corrected for my 35’s with forescan. Still love the look of those wheels/tires! Wondering, have you looked into painting or powdercoating the rear hubs? Might go that direction on wheels down the road. Having a lot of fun with this truck!
I just read this whole thread over the past couple days, great information. I actually found one of your old threads that got hijacked, was trying to find information about tunes, programmers, parts falling off, etc. Anyway I do have a couple questions for you. Have you still not heard anything about the trans tunes from PPEI? Also I know you still have the stock resonator and tail pipe so what kit did you use exatly for the exhaust?
I have not hesrd anything else, im going to follow up again shortly . Last i heard tunes were done but ez lynk/ auto agent was working on the capability to flash the tcm. Im ready, i hate the stock slushy power wasting heat building shifts. I used a flo pro pipe and i was dissappointed with the fit. It took some time with a welder and torch to modify and add a few hangers to get it properly secured in order to prevent drone and to get the tail section positioned close to stock. I would like to think they have this corrected now. But i would highly reccomend keeping the stock tail and resonator if you dont want to hear drone in the cab. The weight, vibration damper and stock resonator are all there for a reason, and thats why i have no drone.
#168
Awesome, no problem. At the time there was hardly any info out there so i wanted to try and do my part to get something out.
#169
Becorum - I’ve been thinking of running my setup like Kubota’s also(thanks for the great info btw!) but maybe cut the dual tip off and add something better looking. I dont think that should affect sound much at all. Haven’t looked into the availability of a part that would fit though, maybe someone could weigh in on that.
#170
#171
#172
3.5" is what I was thinking, I do know a tip has a pretty big impact of how they sound at WOT. I had stock exhasut on my 6.0 with cat and muffler deleted and a 6 inch tip and it was loud. I replaced it with full 4" straight piped MBRP with no tip and it was more quiet than the other setup. I put another 6" tip in the full straight pipe and the volume was back to loud. Just my .02
#173
#175
4" full Flo Pro is what I'm running. Fit perfectly. I'm now adding a "Twister" resonator to eliminate the little bit of drone.
Also considering adding a muffler. Last cold start you'd thought an airplane was about to take off. Im sure my neighbors love it. Much louder than my 2011 with 4" AFE exhaust.
#176
https://youtu.be/pZ80oq-zzCE
#177
From Flo Pro - the “twister has been a great success with 0 complaints when it comes to eliminating drone”The muffler will not help with drone, just cut down on the overall noise. My 4” sounded like a 5” when it was all done. Don’t get me wrong, it sounded nice..but didn’t want to be that guy in the neighborhood that rumbles up and down the street.
#178
In all the exhausts i have built on gassers and diesels (probably 20 or so), i have learned alot of time drone is solved by stopping the pipe reverberating or vibration at certain rpm, more so in longer runs of pipe. This can be accomplished by adding dampers or additional hangers. Also you can use the method alot of car makers are using in mufflers not and actually weld a calculated length of pipe to the outside exhaust tubing to stop the drone. 90 it off and run parallel with pipe. Look at the new f150 muffler on the 5.0. Its straight through with a series of small pipe welded to the straight thru section tuned just right to have no drone but max flow.
Ive also always had great luck with Donaldson mufflers at stopping drone for a simple approach.
i had a 40" on a few trucks, which is straight through with a chamber, this one lets the exhaust talk, turbo whistle but no drone, and can be had fairly cheap from any truck dealer.
The Donaldson resonator does something similar but on a lesser scale and is cheaper.
the Straight thru version of the 51" Donaldson will make it almost sound stock with a VVT but will still flow everything a 4" or 5" pipe will throw at it.
#179
You say you have 37x12.5 RT's on 20x9 +18 offset, this is the EXACT setup I want to use with a 2.5" carli front level. However I am very afraid it will rub on the radius arms and swaybar. I started a thread on this and had two people say they have this setup and theirs rubs:
https://www.ford-trucks.com/forums/1...ffset-rub.html
Are you 100% sure you have no rubbing anywhere? I am trying to gain confidence on the +18 offset, as I want to avoid 0mm offset as I think it sticks out a bit too much for me.
Your help is appreciated!!
#180
Kubota,
The last time i trimmed the mud flaps i did do some testing twisting up the suspension trying to make them rub, could be where radius arms got touched? who knows.
On another note word is on the street the ez lynk tcm flashing is working for the beta testers and is up for release any time? fingers crossed and expectations lowered
