Question on newly wired in radio
Old Mar 26, 2017 | 11:38 PM
Mitchel Wincentaylo's Avatar
Mitchel Wincentaylo
Hey guys, just thought I'd bug you all for some pointers. I just bought a cd player/radio for my 69' f250. I ran brand new wiring for the ground and 12v power, and I stuck the cd player in the glovebox (like hell I'm actually going to "modernize" the look) so after I wired up the speaker( put a cheepie under the seat) and hooked up the ground, I connected the power supply to the fuse box, and slid in the connector to the lights/ dash illumination fuse. All ran great and everything was working until it started blowing the fuse. I'm going to assume that either the cd player is too much power and will keep overloading the circuit? Should I be hooking it up elsewhere for its power supply? I want to avoid hooking it up directly to the battery. Any input would be appreciated!
Old Mar 26, 2017 | 11:51 PM
Uni Moe's Avatar
Uni Moe
On the fuse panel there are a couple of spots where you can use a spade connector to wire direct to the panel but you'll need to have an in line fuse on that wire.
Old Mar 27, 2017 | 12:12 AM
Mitchel Wincentaylo
Ok, cool. Yeah I did notice those today when I was hooking it up, but never gave it any thought. Lucky me, I bought an inline fuse when I was at Canadian tire earlier today just cause I thought I might need it. I will try it out in a bit and see how she works.
Thanks man!
boxcarracer955
Apr 11, 2015 08:55 PM
BEAST2002
Dec 25, 2014 01:10 AM
ejolliffe
Aug 15, 2007 07:45 AM
Monarchfootbal77
Oct 30, 2006 09:35 AM
AYORK3177
Sep 27, 2005 04:22 PM
