02 7.3 help please
Old Mar 26, 2017 | 12:17 PM
Chance Wise's Avatar
Chance Wise
02 7.3 help please
so hello everyone first time posting last Thursday washed my truck driving home it dropped rpms then picked them back up did that 3 times then died hasn't started since checked all Fuzes and relays inside the truck all good don't have a way to check the relays under the hood. replaced the the cps checked the wire harness under the value covers have fuel Goin to and leaving the fuel bowl got a scanner and my rmps go up when I crank my hpop reads 2000 my ipr reads 14.7 eot reads 40 is there anything else o need to look for any help would be greatly appreciated need some help for guys that know more than I do
Old Mar 26, 2017 | 12:30 PM
Walleye Hunter's Avatar
Walleye Hunter
1) Did you use OEM CPS? Aftermarkets have a track record for not working right, even right out of the box.
2) Any windshield leaks letting water get onto/into your PCM or GEM? Look around for moisture under the dash.
Old Mar 26, 2017 | 01:10 PM
Chance Wise
I got it from ford it's the gray one and I'm not seeing and leaks or moisture around there
Old Mar 26, 2017 | 04:05 PM
hydro man 17's Avatar
hydro man 17
As far as fuel related issues go... How much fuel in the tank? More than 1/4? You could see fuel flow at the bowl with no load but not enough to sustain 60 PSI while running. Possible clogged screens in the tank as well.
Old Mar 26, 2017 | 04:45 PM
Chance Wise
I have a little under 3/4 of a tank
Old Mar 26, 2017 | 05:08 PM
Rikster-7700's Avatar
Rikster-7700
What's your oil level? These trucks need oil to run....
Old Mar 26, 2017 | 05:14 PM
Chance Wise
she is full just changed it 50 miles ago
Old Mar 28, 2017 | 11:23 AM
BillyBob69's Avatar
BillyBob69
If this only happens when you wash the truck or it rains I would have the windshield pulled, cleaned and resealed. Known issue for water to drain the A pillar and cause issues when it hits the back of the fuse panel and the GEM on older models.
frdf250
Jun 5, 2018 09:38 PM
Diesel cat
Jul 25, 2015 11:08 AM
bruno2
Jul 2, 2015 04:42 PM
Pmcfall
Jan 9, 2014 07:08 PM
15 and 92 Dad
Jan 29, 2008 05:04 AM
