Traction bars
Old Mar 25, 2017 | 09:52 PM
s120483's Avatar
s120483
Traction bars
So as I sit and wait for my truck I have question on traction bars. The truck is a F350 CC SB SRW 6.7. I do plan to do a 6" lift and 36" tires on the truck once it is here. I know traction bars are not part of the kit I want from Fabtech. Also, I must say I really dislike the look of traction bars on a lifted truck. Never have liked them, just a personal preference. I am curious whether I really do need to get them for reliability of the truck? This truck is my daily driver, use if for farming and personal use. I don't drag race or go to the track at all. I tow some, but not real heavy. Maybe a couple times a year and would be surprised if total trailer weight was close to 10,000 lbs. I do plan to do some tuning, but not planning any crazy HP levels. No compound turbos or fuel system upgrades. Just want to make sure the truck will be a reliable, comfortable daily driver without traction bars since I don't like the look. Or do I absolutely have to have them? Thanks for the help guys.
Old Mar 25, 2017 | 10:10 PM
cyncwby's Avatar
cyncwby
Traction Bars??? Why? If Fabtech thought they were necessary with their lift kit then they would design, mfg. and include them. I've had 3 Superduty diesels, never had traction bars and never needed them.
Old Mar 26, 2017 | 03:37 PM
FONRDAY's Avatar
FONRDAY
I would stay away from Fab Tech
There kits are Lousy.
Old Mar 26, 2017 | 03:52 PM
maypo59's Avatar
maypo59
Can you go in to more depth with that comment?
Old Mar 26, 2017 | 03:57 PM
s120483's Avatar
s120483
Yes please elaborate on why they are not good? Who makes a better 6" lift kit that I should consider? I was wanting to do the Fabtech 6" 4 link with coil replacements and steering stabilizers. Thinking Dirt Logic resi shocks all the way around. Not a good idea?
Old Mar 26, 2017 | 05:57 PM
FONRDAY's Avatar
FONRDAY
Yeah
yeah the welds break and had problems with the gemomenttary wreaking havoc on suspension components they are okay for small pick ups
Old Mar 26, 2017 | 06:16 PM
s120483's Avatar
s120483
What year truck did you have the lift on?
Old Mar 26, 2017 | 06:59 PM
FONRDAY's Avatar
FONRDAY
on a 2016 superduty
many shops on my area won't install fab tech and now I now why
Old Mar 26, 2017 | 07:09 PM
Sterling6.7's Avatar
Sterling6.7
PMF for the lift, Fox shocks and OUO for the bars. Some of the best around.
Old Mar 26, 2017 | 07:56 PM
FONRDAY's Avatar
FONRDAY
OUO is the best
One up off road is awesome I have never used pmf lifts but for shocks I like king or Fox
Old Mar 26, 2017 | 08:30 PM
eberlestock's Avatar
eberlestock
You will only need traction bars if your truck has wheelhop. If it has wheelhop stock, it usually gets worse when lifted. If your truck hasn't got wheelhop then don't worry about it. Some dutys have horrible wheelhop and others have none!
Old Mar 26, 2017 | 08:55 PM
FONRDAY's Avatar
FONRDAY
Just
just use a nice 4 link system and life is good
Old Mar 26, 2017 | 09:31 PM
Jbair14's Avatar
Jbair14
PMF 3.5" Alpha lift. If you plan on adding any power traction bars are absolutely needed!!
Old Mar 26, 2017 | 09:47 PM
MagicMtnDan's Avatar
MagicMtnDan
Don't do traction bars unless you're sure you NEED them. Traction bars will help reduce/eliminate rear wheel hop BUT they affect the rear suspension changing the range of motion because of the traction bars' pivot point(s).
If you don't like the look that's another great reason not to get them unless the wheel hop is bad and you want to stop it.
Old Mar 27, 2017 | 04:26 AM
Chris Crews's Avatar
Chris Crews
Yeah just curious why fab tech is badz their product is like $$$$ so I would assume it's good quality. Personally I was gonna go with a BDS 6"
