Tire Balancing beads. Anyone use them?
One of the other automtive forums was recommending "balancing beads" for large (38"+) 4x4 tires. I also saw a product where a disk filled with beads was sandwhiched between wheel and brake drum/disc rather than loose beads inside the tires.
Products | Counteract Balancing Beads and http://www.innovativebalancing.com/index.php
Has anyone ever used these? What do you think?
Does This Really Work? Tire Balancing Beads - Hot Rod Forum : Hotrodders Bulletin Board
I've read a lot of forums on this subject now. Unfortunately, it still seems to be about 50/50 consensus on whether or not they work. It almost seems the 50% that don't like the idea never tried it. It is more accepted on the semi-truck forums.
I'm getting a new set of tires (37") in a few weeks. BTW - I have top buy new wheels too because you can get a 16.5" rim-size tire any more. I'm going to have them "Road Force balanced". If I have any balance issues (or if any crop up later) I'll give the beads a try then.
It just seems that if these beads really worked they would be offered by every tire shop.
drewduncan15
03-23-2018 08:04 PM
