Bronco II Ford Bronco II
Borg-Warner 1350 Transfer Case
Old Aug 31, 2003 | 06:00 PM
dbthumper1's Avatar
dbthumper1
Thumbs down Borg-Warner 1350 Transfer Case
Im having a problem with my electronic transfer case. There is a long story behind it, but i dont know what it is. This case was in the 4wd parts truck that i bought. When i first got my 87 it was 2wd and i swapped every thing in that i needed. Regular 4wd on the case works perfectly, but Low Range just flashes at me, and i was wondering if anyone knows anything about it.
Old Sep 1, 2003 | 12:10 AM
bigfry's Avatar
bigfry
I'd check the shift mechanism on the T case and see what it does when you move the in cab switch. Or hook the wiring at the T case up to a jumper wire and see if it moves, if not its probably bad. You could possibly have a grounded wire, bad in cab switch, or something phisically enabling the shift from happening weather it be some kind of debris, or something broken. Thats all I can think of off hand. Probably won't help but I tried.
Old Sep 1, 2003 | 12:18 AM
lakahahahman's Avatar
lakahahahman
in my manual for this t case i says if it just flashes at you to stop the truck and put it in N then engage low range and it should stop flashing
Old Sep 3, 2003 | 07:33 AM
NakedDucks's Avatar
NakedDucks
Electric t-cases are crap....the motors go out all the time...swap to a manual. I can tell yuo how and all that's needed....I also have the parts......I had the same problem, but it's fixed now!!
Old Sep 3, 2003 | 09:47 AM
dbthumper1's Avatar
dbthumper1
thanks for all the replies ill check out what all of you said and tell you what happens
Old Sep 3, 2003 | 02:08 PM
lakahahahman
what are all the parts needed to swap to a manual TC
is the floor already prepped for a shifter or do i have to cut a whole in the floor to install it
Old Sep 3, 2003 | 03:42 PM
NakedDucks's Avatar
NakedDucks
Here are 2 write ups..........
https://www.ford-trucks.com/yabbgold...227736;start=0
www.broncoii4x4.com
-click on "shop talk"
-scroll to the bottom
Please aks anything else you need to know....
Old Sep 3, 2003 | 08:41 PM
lakahahahman
An Error Has Occured!
This field only accepts numbers from 0-9
this is what i got from that link
Old Sep 3, 2003 | 10:58 PM
NakedDucks's Avatar
NakedDucks
And the other link? It's the same, accept it has pics w/ it!
Old Sep 6, 2003 | 08:37 PM
mjb1962's Avatar
mjb1962
Old Sep 6, 2003 | 08:38 PM
mjb1962's Avatar
mjb1962
There is a transfer case speed sensor on the back of the case. Mine "opened up" and gave the exact symptom you describe. About $70 from the dealer.
Mark
tbruz
Oct 28, 2015 03:20 PM
benmoderow
13
Aug 17, 2015 02:38 PM
66Charlie
Jan 25, 2013 09:47 AM
MikeRizz
Jan 23, 2012 04:23 PM
driptorch970
2009 - 2014 F150
Dec 21, 2010 11:39 AM
