Gaps in Bed construction
Old Mar 23, 2017 | 01:16 PM
troverman's Avatar
troverman
Aluminum may expand / contract / flex differently than the steel beds of the past...necessitating larger gaps. Just a theory. I'm totally fine with the construction of the bed.
Old Mar 23, 2017 | 01:49 PM
cyncwby's Avatar
cyncwby
Man am I stupid, I totally ignored where that pictured gap was, thought it was the wheel well area. So yes you are correct, my '16 dually has the same gap back there also even with factory spray in liner.
Old Mar 23, 2017 | 02:06 PM
oklarado's Avatar
oklarado
Did the OP get the wheel well liners installed? Perhaps that'll make a difference. I have the wheel well liners, tomorrow I'm getting a spray in liner and leer camper shell so I'll see how it does in water.
Old Mar 23, 2017 | 03:01 PM
Kenv's Avatar
Kenv
Originally Posted by oklarado
Did the OP get the wheel well liners installed? Perhaps that'll make a difference. I have three wheel well liners, tomorrow I'm getting a spray in liner and leer camper shell so I'll see how it does in water.
Good point....I have the wheel well liners and haven't noticed any spray up through the gaps.
Old Mar 23, 2017 | 03:37 PM
Jrbonniwell's Avatar
Jrbonniwell
Not to hijack but be sure to post a picture of that shell tomorrow!!
Old Mar 23, 2017 | 03:55 PM
Pintabo's Avatar
Pintabo
Trailering
No, I don’t have the wheel well covers – but I will check into them now. Just seems absurd that I need to add an aftermarket upgrade in order to correct sloppy work.
While I understand that some of the gaps/holes may be left intentionally for water to drain, it sure seems that an engineer could have easily added a deflector plate or something to the underside so that mud/water won’t get slung up and into the bed – pretty simple addition during construction if it is thought through.
And no, this issue is not caused by someone adding a bed cover. If I am hauling my fishing gear, hunting gear, new furniture, new mattress, etc. in the bed of my truck (with no cover), I would have to avoid any kind of water or puddle in the road. If not, mud/water will be tossed on my cargo via the rear wheels – how can some of you say that is acceptable? That is ridiculous.
I agree, the spray-in bedliner would fill in some of the gaps, but not the holes in the corners. Looks like I will try the silicon option – unless someone thinks or something better.
Old Mar 23, 2017 | 04:05 PM
oklarado's Avatar
oklarado
The liners are not aftermarket, they are an option. Like everything else Ford tries to keep the base price down and you pick the options.
Old Mar 23, 2017 | 05:00 PM
reseehc_99's Avatar
reseehc_99
The aftermarket I believe he was referring to is the bed cover, not the bed liner.
Just to play devil's advocate, why don't the factory option plastic drop in bed liners have drain holes in them? My dealer installs these on every short box truck on the lot and it's not uncommon to see 4" + of standing water in the trucks after a good rain.
Old Mar 23, 2017 | 05:08 PM
mlsjohn's Avatar
mlsjohn
I have the same gaps and used silicone to seal it because I have a topper on mine and did not want the dust and water in the bed.
Old Mar 23, 2017 | 05:23 PM
AMXDREAMER's Avatar
AMXDREAMER
You can get a black caulk that is flexible that will blend in with the spray on.
Old Mar 23, 2017 | 06:31 PM
reseehc_99's Avatar
reseehc_99
If you're going to get an aftermarket spray in bed liner you can fill those gaps beforehand to give the liner something to hold it in place untilit cures. You can get foam designed for filling expansion gaps in concrete block walls. It is available in different sizes and comes on a roll.
Old Mar 23, 2017 | 07:59 PM
bikerman5345's Avatar
bikerman5345
Ford factory liner and full underbody coating. My bed stays dry. Still have small amounts of daylight but I haven't seen anything coming up through them and I've been driving in snow and salt and everything else.
Old Mar 24, 2017 | 06:52 AM
  #28
troverman's Avatar
troverman
...And no, this issue is not caused by someone adding a bed cover. If I am hauling my fishing gear, hunting gear, new furniture, new mattress, etc. in the bed of my truck (with no cover), I would have to avoid any kind of water or puddle in the road. If not, mud/water will be tossed on my cargo via the rear wheels – how can some of you say that is acceptable? That is ridiculous.
In fairness, most new mattresses and furniture comes fully wrapped in plastic, so there wouldn't be an issue there.
In my own experience, the bed of my truck remains very clean. It is not filling up with dirt and water. I have no cover, just the factory spray-in bed liner.
Old Mar 24, 2017 | 10:15 AM
  #29
Ryanf73's Avatar
Ryanf73
Here are some pictures between the wheel well and the cab. I can see tbe ground while standing in the bed looking down...
Old Mar 24, 2017 | 10:42 AM
  #30
troverman's Avatar
troverman
Spray-in bed liner solves that problem. I don't think any bed has continuous weld, which could cause cracking and also adds weight.
I'm still not seeing the problem here. If you want everything to be under cover and not getting dirty, buy an SUV. If you do want to make you pickup bed like an SUV, you can do that too...but its going to require a topper, tonneau, or some kind of bed liner. Next time I might try the bed rug, looks pretty cool.
