Temp Sensor?
Old Mar 22, 2017 | 01:13 PM
eric8's Avatar
eric8
Temp Sensor?
Quick question....is this sensor pictured on the intake manifold neck not the sensor for the instrument cluster's temp gauge on a 302? I can unplug this and the temp gauge still seems to function normmally. If not, where is the actual temp gauge sender located?
Old Mar 22, 2017 | 01:16 PM
meangreen92's Avatar
meangreen92
That's your Temperature Controlled Vacuum Switch. Dunno about the electrical connector on it though, never seen that.
If it's a 302, your temperature gauge sender should be on your intake manifold, just behind the thermostat housing. It will have a single wire with a connector just like those on the small wires on your starter solenoid.
Old Mar 22, 2017 | 01:37 PM
eric8's Avatar
eric8
Ok thanks...I'll look a lil closer but I'm not seeing anything else with a wire going to it in that area. Maybe you can answer a related question....the sensor that I photographed and also the ambient air temp sensor in the air cleaner....can the wiring to these be deleted? Do these two sensors provide inputs to the duraspark module? If deleted will it cause issues? I'm trying to clean up and simplify my engine compartment to resemble something a little more "pre smog"
Old Mar 22, 2017 | 01:39 PM
eric8's Avatar
eric8
FYI I have already ordered a recurved Duraspark distributor to work with the deleted EGR, and my state does no emission testing
Rico47635
Oct 5, 2011 11:15 PM
aking225
Aug 26, 2010 07:58 PM
kodiak 55
Electrical Systems/Wiring
Mar 16, 2004 03:40 PM
childsplay
Oct 28, 2003 10:39 AM
GeneStoner
Apr 18, 2003 12:48 AM
