temp sending unit??
right now I have about 107000 miles on it
Recently, I have been noticing that my temperature gauge is acting strange. When started it will usually slowly move up to the normal operating temp readings, someplace between the C and the N in normal. During hotdays, it has recently started hitting the N or slightly higher, then in a few minutes it will drop back down to what I consider to be the normal temp reading for this truck. On cooler night drives, it will occasionally stay below the C and then pop up to normal and back down under the C in a matter of 10 - 30 seconds.
I have replaced the the thermostat thinking at first that it may be going bad, but it continues to happen. I have asked many people with much more automotive experience than I have, and they all seem to think that the temp sending unit is going bad. I tend to believe them, but I would like additional input.
Coolant levels remain constant, its not dirty, but there a few floaties in it. Not sure what from, but they look kinda white.
I beleive that I should replace the temp sending unit regardless,
Where is it located ???? I have looked over the whole engine and can not find it.
BTW, i have the haynes manual for 83-93 Rangers/Broncos -- Since i have the 93, it should show me, but it does not --
The temperature sending unit has only ONE WIRE going to it and on 4 cylinder engines it is threaded into the engine block on the driver's side, at the rear, just below the cylinder head.
Good luck, and welcome to Ford Truck Enthusiasts!
I am getting plenty of flow, and it was evident when I increased the engine rpms, -
about the temp senind unit, looks like i am going to have to crawl under the truck to get to it
at least I dont need a jack
