FORD mud flaps are nice
Old Mar 19, 2017 | 04:32 PM
jimzpsd's Avatar
jimzpsd
Sorry I was away, thanks to the others that posted pics. This is the video that convinced me to purchase these. JDman if your out there, THANK YOU.
Old Mar 19, 2017 | 05:48 PM
fordman19762003's Avatar
fordman19762003
Originally Posted by K2500Z71
x2. Those barbs on the clips look like they'll take the paint off the back side of the fender lip when they get installed. I may just take my chances and go without when I get mine this fall. I didn't put flaps on my '12 Denali and now 5 and 1/2 years later, I have ZERO chips on the rockers/lower-body. I would assume that Ford is using a similarly tough paint along the lower body.
There has been a lot of people saying that the paint on the newer trucks chips pretty easily. I guess the durability of water based paints is less.
What I've done in the past when I had to drill holes to install stuff is to put a bunch of silicon around the fastener to seal out moisture and have never had anything rusting issues.
Old Mar 19, 2017 | 05:56 PM
fordman19762003
Originally Posted by TrikeDawg
I have the OEM flares and I was able to get the clips over on the metal on the fender and the flare to secure the flare. I'm not worried about the paint because of the aluminum body.
Thanks for the photos. They answered my question about how the OEM flares mount. In the one photo of the rear you can see the push pins go up around the radius of the wheel well which are used to hold the flare in place.
This is the same set up Ford has used on the F150s since '04. It works good but it makes it very difficult to install some take off OEM flares since it's harder to get the holes drilled correctly.
Old Mar 20, 2017 | 12:41 AM
DingusKhan's Avatar
DingusKhan
Originally Posted by petei
Man,Gotorback flaps looks a lot better.
I don't think so. They are too flashy. These don't stand out and draw attention.
pickerdd
Oct 9, 2017 10:02 PM
dannko
Feb 20, 2017 12:42 PM
FONRDAY
Jan 22, 2017 06:22 PM
celeste646
Dec 21, 2016 10:23 AM
awq134
2009 - 2014 F150
13
Feb 5, 2010 09:07 AM
