Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
08 edge headlights quit working
Old 03-18-2017, 12:03 AM
Ammotrp69's Avatar
Ammotrp69
Ammotrp69 is offline
My headlights quit working on my 08 edge limited. The bulbs and fuses are fine. I've checked and I have power at the harnesses. High beams, turn signals, parking lights, fog lights all work, just no low beams. I replaced the headlight switch to no avail. What else am I missing?
Old 04-21-2017, 05:47 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
If you see 12 volts at fuse 7 & 8 (10 amps) in the SJB/smart junction box the only thing that makes any sense is that 1 bulb burned out & you did'nt notice until the 2nd bulb burned out. I've been there & done that myself.
Old 04-21-2017, 09:46 PM
Ammotrp69's Avatar
Ammotrp69
actually, no. i jimmy rigged the low beams to the high beams, and the bulbs are just fine. i found that my grounds are gone. i haven't had the time to do it yet, but i'm going to ground them direct to the battery.
Old 04-22-2017, 02:14 AM
87 XLT's Avatar
87 XLT
87 XLT is offline
Someone must have done some creative wiring on these circuits??? The diagram shows the ground wire from left high beam & left low beam are spliced together & are grounded at G 104
Same on the right side and the common ground is G 107.
I hope you don't find any more surprises like this
mechasus
Escape & Escape Hybrid
10-25-2021 04:06 PM
lrh2phish
2009 - 2014 F150
01-14-2019 01:46 PM
$ledgehammer
1999 to 2016 Super Duty
08-26-2017 11:51 AM
49fordv8f4
07-08-2016 10:10 PM
HUNTER10
10-04-2009 07:40 AM
Quick Reply: 08 edge headlights quit working
