steel wheel question
Old Mar 17, 2017 | 03:28 PM
tom from mass's Avatar
tom from mass
I have a 1997 F-250 XL. Original steel wheels 8 lug 16" tires. I noticed some vibration at 30 mph and higher. Brought to Ford dealer for rotate and high speed balance. I asked the 20 something young mechanic if he had any formal mechanical education as he seemed to have a very hard time using the high tech computerized wheel balancing machine. He informed me that he wasn't able to get a perfect balance because of some corrosion. Could he have used a power wire brush or similar to clean the mounting surface? If his explanation makes sense could someone please advise? Do steel wheels wear out if they have a tire on them and are always on the truck?
Thanks,
Tom
Old Mar 17, 2017 | 11:08 PM
kellen302's Avatar
kellen302
Wire wheels are fine for steel wheels, I have used them frequently to clean up a wheel before painting to remove old paint and rust.
Steel wheels do not wear out as far as I know. They can be cracked or bent from a hard hit, and technically there can be fatigue failure if you do the engineering fatigue analysis. But I have never seen one on a car/truck just "wear out".
Old Mar 18, 2017 | 07:58 AM
'89F2urd's Avatar
'89F2urd
I could see how corrosion could be a recipe for an awkward balance, but the balancing would still be the same as any other wheel. It's not rocket science.
There are a ton of variables that come into play when balancing; quality of tire and/or normal manufacturing flaws, bent or wheels that aren't true within spec, size (larger they are, the harder they are). I don't see how corrosion would be any different than dealing with any of those.
applebaggins
Aug 21, 2017 07:41 AM
milkweed.gardener
May 27, 2017 11:47 AM
Kdr358
Mar 25, 2012 12:25 AM
raytasch
Sep 7, 2011 11:53 PM
spikedog
General Automotive Discussion
Oct 19, 2009 09:49 AM
