88 f150 losing power to coil
Old Mar 16, 2017 | 07:28 PM
DCintn's Avatar
DCintn
I have an 88 f150 4x4 5.0. Bought it 6 months ago. Drove great on the hour long trip home. A couple days later, my wife drove it to town. 5 minute trip. It died and wouldn't start back. A new distributor and it fired back up. But now it does just like the key was shut off. So far I've put new distributor, cap, rotor button, plugs, wires, coil, fuel pump relay, fuel pump, map sensor, tfi, heat sensor, ignition switch, fuseable link, starter solenoid. Ended up taking it to a shop, and they also failed to find the problem after having it for a week. Somebody tell me what to do before I burn it in my drive way!
Old Mar 16, 2017 | 08:29 PM
alloro's Avatar
alloro
Does it have a security system or a chip key?
Old Mar 16, 2017 | 09:06 PM
DCintn's Avatar
DCintn
88 predates all that chip crap
Old Mar 16, 2017 | 10:52 PM
joey2fords's Avatar
joey2fords
please clarify, is it starting and then dying, or not starting at all ? if the latter, is it cranking ?
Old Mar 17, 2017 | 12:05 AM
DCintn's Avatar
DCintn
Cranks and runs, then just dies like it's been turned off. Will start right back up, but you have to turn key completely off to get it to start back
Old Mar 17, 2017 | 12:57 AM
joey2fords's Avatar
joey2fords
then my next move would be to check fuel pressure with a gauge, and pull codes.
also, can you hear the fuel pump run for a second before starting, or does it run continuously if the key is in the run position ?
Old Mar 17, 2017 | 01:02 AM
joey2fords's Avatar
joey2fords
also, you say you replaced the ignition switch. do you mean the switch thats mounted to the steering column, up underneath the dash, or do you mean the ignition lock, into which the key goes (this is often mistakenly referred to as the ignition switch).
Old Mar 17, 2017 | 03:12 AM
DCintn's Avatar
DCintn
I've done those. Im very mechanically inclined. I know fords, been driving them for 24 years. But this one has me stumped. I'm the guy that has done a little bit of everything that others come to when they need their crap fixed lol. This truck beeen kicking my *** though. That's why I'm here, I'm looking for what I haven't thought of.
Old Mar 17, 2017 | 03:15 AM
DCintn's Avatar
DCintn
Oh, forgot, no I didn't change the key cylinder, I changed the switch
Old Mar 17, 2017 | 06:51 AM
subford's Avatar
subford
You bough a rebuilt distributor and most of them are bad and do this.
You need to either replace the PIP sensor in the distributor or buy a "NEW" distributor, not a rebuilt or remanufactured distributor and put it in.
Old Mar 17, 2017 | 10:33 AM
vjsimone's Avatar
vjsimone
How often does it shut off ?
Any codes?
Might as well throw an EEC relay in her as well...
Old May 24, 2017 | 04:05 PM
DCintn's Avatar
DCintn
Sorry I haven't had a chance to get back on. It was the reman distributor. Got a new one, truck runs great.
Jeff Metz Jr.
16
May 24, 2017 11:01 PM
77 1/2 F250
1983 - 2012 Ranger & B-Series
Jul 17, 2012 07:39 PM
LI250
Aug 26, 2010 06:36 PM
pmipmatt73
Nov 1, 2007 03:26 PM
firebug
Oct 1, 2003 11:32 AM
