Dana 30 or ??
Old Mar 16, 2017 | 03:38 PM
HomerAKF250's Avatar
HomerAKF250
Dana 30 or ??
How would i identify a dana 30 rear axle? I have one that has a big "30" cast into the pumpkin. Does that make it a dana 30? It has 8 lugs. Should i have any problems putting it in place of the factory sterling axle?
86 f250 4x4 460cid
Old Mar 16, 2017 | 03:45 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Sorry, I can't answer the Sterling swap question but I'm sure someone will chime in shortly. And welcome to FTE !
Old Mar 16, 2017 | 03:50 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You have a Sterling 10.25" rear end.
They were introduced during the 1985 model year.
Old Mar 16, 2017 | 04:03 PM
WhatsAChevy?
Ard...I think the OP is looking to swap out his Sterling for what is possibly a Dana 30 ?
Old Mar 16, 2017 | 04:34 PM
FuzzFace2's Avatar
FuzzFace2
It is kind of confusing what he wants to do but if that axle with the 30 on it has 8 lugs then I am pretty sure it's not a 30.
A 30 would be a light(er) duty axle and think it was used in Jeep JC5 & CJ7.
I think a 9" would be stronger than the Dana 30 and it has 5 lugs.
So if that "other" axle has 8 lugs you will have to look at the chart and see what it is.
Dave ----
Old Mar 16, 2017 | 04:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I guess i misread. ☺
I can't think of a reason to swap out something as bulletproof as a 10.25 under normal conditions.
Eight on 6 1/2 is not too unusual, but i doubt i would want to put a smaller axle behind a 460.
Old Mar 16, 2017 | 05:08 PM
WhatsAChevy?
86 f250 4x4 460cid
If I get it right, it sounds/reads like you are looking to replace your current 10.25 Sterling axle with one that you "believe" is a Dana 30 ? Is the Sterling locked up ? If you could, pics of both differentials would do wonders here. You could have not picked a better site for your inquiry but a little more info for clarification would be a big help.
Old Mar 16, 2017 | 08:37 PM
Franklin2's Avatar
Franklin2
Ford only used Dana 60/61 8 lug axles or the Ford/Sterling 8 lug axle for these year trucks. If you have a fill plug on the back cover, you have a Dana 60 if it's single rear wheel. If you have no fill plug in the rear cover, then you have a Ford/Sterling rearend already.
Old Mar 16, 2017 | 08:43 PM
HomerAKF250
The old sterling axle
Old Mar 16, 2017 | 08:50 PM
Franklin2's Avatar
Franklin2
Looks like the bearings went south. I bet that has been making noise for awhile before it let go.
Old Mar 16, 2017 | 08:55 PM
HomerAKF250
New mystery axle (leaf springs are now gone)
Old Mar 16, 2017 | 09:10 PM
rowdyredneck's Avatar
rowdyredneck
That's a semi-floater C-clip Dana 60 I believe. Ford used them in lighter duty F250 trucks in the 80s. My '84 originally had one of those but the axle shafts were shot from the bearings eating into them so I swapped in the Sterling. That axle will bolt right but it won't be as strong as a Sterling. They use smaller 1/2" wheel studs too so you'll be stuck with two different sizes of lug nuts. You may need to modify the driveshaft too because as I remember the length is different. Since your truck is a 4x4 you'll have to make sure it has the correct gear ratio as well.
Old Mar 16, 2017 | 10:14 PM
SpencerS's Avatar
SpencerS
Might be cheaper to try and find another sterling axle instead of swapping axles, as modifying driveshafts can get pretty expensive, if it is indeed a different enough length
Old Mar 17, 2017 | 10:10 AM
Franklin2's Avatar
Franklin2
86 f250 4x4 460cid
You have 4x4 so you have to be careful what gear ratio you are swapping in place also. Look at the axle code on the door jamb on the driver's side and post that, we can tell you what ratio you have.
Like the others mentioned that axle you are looking at putting in is not as heavy duty as the one you had. If it's the correct ratio, it would get you going though.
The original axle; Did it chew up the spindle bad?(the snoot where the axle is coming out of).
windsor94
13
Aug 4, 2008 05:38 AM
fatdaddy
Jan 1, 2002 07:41 PM
