Sponsored by: Real Truck
99 V10 shift issue
Old Mar 16, 2017 | 03:19 PM
Jeremy Vandenberghe's Avatar
Jeremy Vandenberghe
99 V10 shift issue
i have a 99 F350 V10 that has started with shift issues. While driving in drive it will down shift to first for no apparent reason and not shift back up. If I drop the shifter to second it will go back into second from first. I can then shift back to drive and it goes back to drive. It will last a few minutes and then down shift again. It's a dually dumper if it matters
thanks
Old Mar 16, 2017 | 03:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are several potential causes. Does the OD OFF light work when you press the button on the end of the shift handle? Has the light been flashing? That would indicate that codes are stored that would help diagnose what's wrong.
Old Mar 16, 2017 | 07:43 PM
Jeremy Vandenberghe
The OD button and light seem to function normally.
jeffsk7
Modular V10 (6.8l)
Apr 18, 2016 03:52 PM
RSchoe
1997 - 2003 F150
Mar 23, 2015 05:33 PM
Whitey Ford
Oct 5, 2013 04:20 PM
mohle
Sep 3, 2007 08:04 PM
trsest1
Apr 1, 2004 10:23 PM
