Piston Emergency
Piston Emergency
I have my 460 at a motor shop being worked on its getting a mild build, and the shop can only find stock cast replacement pistons of 8.0 to1 compression at $25 a piston or a hyperuetic for 8.7 to 1 at 125 dollars more per set. He told me that TRW has gone out of business, so i need to find a set of cast or forged pistons to raise my compression to around 9 to 1, for closer to $30 so i can afford this can any body help me out here i have to take the connecting rods done there tomorrow.
Piston Emergency
i always thought that more compression would be better too, but i was ressntly told that for truck& tractor pulling that unless u have something like an NTPA truck it aint necessary if u wanna run pump gas while at a pull with todays gas it is possible to predetonate, which is why industrial gas truck run low compression, anyways at this point i dont have much money left so stock replacement pistons were used to save money and future trouble.
Redmanbob
04-09-2020 12:39 AM
73 ford guy
09-08-2010 07:56 AM
dogsniper
04-24-2007 11:06 AM
76f1390
21
02-11-2004 12:26 AM
