Alternator....which one? Amp requirements?
Old 03-14-2017, 08:17 PM
Jarkill's Avatar
Jarkill
Jarkill is offline
Alternator took a dump..any suggestions on what I should buy?
thanks
Old 03-14-2017, 08:56 PM
RickW2007's Avatar
RickW2007
RickW2007 is offline
I bought a 100 amp, plug position was in a different spot but everything reached works good. I just wonder how the ambulance package one would work.
Old 03-14-2017, 10:31 PM
Jarkill's Avatar
Jarkill
Jarkill is offline
Is 100 amp what I need? I know these trucks need a fair bit of amperage and I don't wanna get stuck with the wrong one. What's the ambulance package got? I'm assuming high amperage and more accessory connections than I need but I don't know. This is my first IDI charging system failure and I don't wanna install some crap that will fail or over charge my new batteries
Old 03-14-2017, 11:51 PM
RickW2007's Avatar
RickW2007
I think the smallest they sell, which I would assume is stock is 60 amps. If i recall the ambulance one is 110 maybe. I know the 100 amp is working perfectly in my 90 model IDI
Old 03-15-2017, 12:07 AM
jmuenchow's Avatar
jmuenchow
jmuenchow is offline
I upgraded to the 130 3G alternator. In my opinion it is a must. At idle the volt meter doesn't flinch it charges well and is worth the upgrade!!! You won't be disappointed!
www.ford-trucks.com/forums/1156489-how-to-3g-install-for-83-92-idis.html
i also like it because it is internally regulated vs the external regulator
Old 03-15-2017, 12:49 AM
wtroger's Avatar
wtroger
wtroger is offline
+1 on 130 amp 3G upgrade. Only way to fly. Lights won't flicker when glow plugs cycle.
Old 03-15-2017, 12:58 AM
genscripter's Avatar
genscripter
genscripter is offline
Third on the 3G. I found my 3G in a 90's taurus in a pick-u-part junkyard. Took the wiring harness with me. Only took a half day to rig up. Here's a good tutorial: https://www.ford-trucks.com/forums/8...-pictures.html
I had so many problems with my 1G even after I would change the VR and alternator out. But once I went 3G, never had any problems yet.
Old 03-15-2017, 05:53 AM
hturner12's Avatar
hturner12
hturner12 is offline
3g all the way
Old 03-15-2017, 09:46 AM
cadunkle's Avatar
cadunkle
cadunkle is offline
Wrong, these trucks hardly pull any amperage. My '86 pulls 33.1 amps with everything turned on for maximum electrical load. A gas truck will use slightly more for the ignition system. The early trucks came with a 42 amp alternator which was entirely adequate but might not make 14v at idle depending on load.
For a bolt in replacement a 65 amp 1g is fine. I recommend swapping to a 130 amp 3g as it's only a little more time and money. The 3g is a superior design, the 130 amp will output nearly 100 amps at idle IIRC and oversizing the alternator will ensure it runs cool.
For a vbelt system a 130 amp alternator for a '95 E-150 with 300 six is clocked correctly and has the right bolt spacing on the mounts for our application.
Old 03-15-2017, 10:33 AM
hturner12's Avatar
hturner12
The junkyards are full of 3gs. This is the write up I followed
Piece of cake 3G alternator upgrade - Diesel Forum - TheDieselStop.com
Old 03-15-2017, 11:45 AM
Jarkill's Avatar
Jarkill
Jarkill is offline
Gothcha! I was wondering why it has a 70amp on it now. Anyway thanks ya'll, I will be looking into the 3G a little later because time and money are both running thin after all the other repairs I've done in the last month. Thanks for the input!
Old 03-15-2017, 11:49 AM
hturner12's Avatar
hturner12
I did my swap for less than 50 bucks
Old 03-15-2017, 01:14 PM
Jarkill's Avatar
Jarkill
Jarkill is offline
Easy swap for sure! Unfortunately I just do not have the time at the moment to search junk yards for a ford taurus and a crown vic. I'll get me an auto parts store one for now and keep my eyes open for the 3G swap in the coming weeks.
Old 03-15-2017, 10:38 PM
genscripter
If you don't want to scour the junkyards, you can just order a 3G alternator from Rockauto and order the conversion wiring off of ebay. Something like this:
Ford 3G Alternator Conversion Harness Connector 1 wire | eBay
Old 03-15-2017, 10:46 PM
Jarkill's Avatar
Jarkill
Jarkill is offline
Ford 3G Alternator Conversion Harness Connector 1 wire eBay
well, that's good to know as well! Don't get me wrong, I love sifting through junkyards, just short on time at the moment. (New born baby and a five year old boy) I got a 70amp motorcraft to get me by till I do the 3G upgrade witch I look forward to doing, cause I love tinkering with these old trucks. Thanks for all the input ya'll! Your collective knowledge is priceless
cheers!
Quick Reply: Alternator....which one? Amp requirements?
