Phaser kit done now runs rough
Old Mar 14, 2017 | 05:00 PM
Cowboy1983's Avatar
Cowboy1983
I bought a 2007 Ford F-150 5.4 with about 163000 miles. First week I got it i heard a rattle in the engine at start then goes away and drives fine. Took it to a shop and said it was the phasers. So I order a kit from Freedom racing. Phasers, tensioners, chains, guides, oil pump. Not the VCT sensors. So I timing it with the crank gear at 11 (teeth) dot on 6 o clock, then timing chain with the marks on the gear and on both phasers match I've even triple check the timing. Put everything back together removed fuel pump fuse so I could built oil pressure first then I put fuse on and started up and ran rough and code p0022 come up and p0358 come up. This is my first Ford timing chains I've done. Any help or ideas would help me figure this out. Not giving up.
Old Mar 15, 2017 | 01:36 PM
82_F100_300Six's Avatar
82_F100_300Six
Have you googled the codes what they are for?
I'm just learning about these engines but could it be a vacuum leak?
Old Mar 19, 2017 | 02:33 PM
Cowboy1983's Avatar
Cowboy1983
I did and no luck and no vacuum leak that I could tell
Old Mar 19, 2017 | 02:36 PM
Cowboy1983's Avatar
Cowboy1983
Took everything off to see if I was off time and this is how it is after turning crank.
Old Mar 19, 2017 | 02:45 PM
Cowboy1983's Avatar
Cowboy1983
Any ideas if the cam lobe are facing the right way??
Old Mar 19, 2017 | 05:10 PM
alloro's Avatar
alloro
The 0022 code means the cam timing is very retarded and the 0358 means there is an issue with the COP on cylinder 8.
Old Mar 19, 2017 | 05:16 PM
alloro's Avatar
alloro
To me it looks like you install the driver's side (L) phaser sprocket 180 degrees off. The chain sprocket is in the correct place, but the phaser is not.
Old Mar 19, 2017 | 05:34 PM
Cowboy1983's Avatar
Cowboy1983
so I would have to remove the phaser and turn the camshaft 180 degree and out the cam back on and line up the line"L"?
Old Mar 19, 2017 | 05:41 PM
Cowboy1983's Avatar
Cowboy1983
if I do turn the phaser 180 degrees wouldn't that make it "R" under the makes on driver side?
Old Mar 20, 2017 | 08:09 AM
alloro's Avatar
alloro
You leave the chain gear right where it is, remove the phaser, turn it 180 degrees and reinstall it.
Old Mar 20, 2017 | 09:03 AM
Cowboy1983's Avatar
Cowboy1983
if I do that and turn it 180 degrees the phaser letter "R" will be up now and I thought driver side suppose to have "L" and passenger side "R"
Old Mar 20, 2017 | 04:50 PM
70f100longbed's Avatar
70f100longbed
The chains are right. You can't turn the phaser 180 degrees on the cam there is a locating pin on the phaser and a slot in the cam. Check the VCT solenoids for any damaged screens maybe there is a piece of screen making the valve stick.
Old Mar 20, 2017 | 05:07 PM
Cowboy1983's Avatar
Cowboy1983
that's what I thought about turning it 180 degrees. I did the test to unplug the VCT wire to see if it made it ran good and still was running rough on idle
Old Mar 21, 2017 | 09:59 AM
Cowboy1983's Avatar
Cowboy1983
removed the VCT and everything looks good. Screens are clean nothing on them
Old Mar 22, 2017 | 11:51 AM
70f100longbed
Are they aftermarket phasers? I havent heard many good things about aftermarket. The runs rough concern is prob from the P0358 code, coil primary circuit failure on #8
