Osagebow, The 3 SOL, if you have them should be mounted to the left side of the valve cover.
IIRC my truck only had 2 of the 3 and nothing was hooked to them so when I get my truck back together they will not be installed.
Dave ----
Thanks guys for the diagrams and advice! Got her tubes all tied up and was able to walk the curb idle down to 600. This would have been a sure stall before. She had sputtered occasionally on shutdown , that seems fixed also.
A search led me to your thread. Do you mind if a join the party a little? I'm hunting vacuum gremlins as well. If I don't have an ERG solenoid can I bypass EGR diaphragm directly to the carb? Is the carb port (#3 in the photo?) the higher one on passenger side of choke plate?
