Hey guys, I'm back with an old issue I've been chasing for a while. Here's the best I can describe it:
My truck (read sig.) occasionally hesitates at low speed take offs. Only occurs when it warms up. How it happens is usually, from a stop I will accelerate, RPMs up to 1100 and it will suddenly bog down to 900-1000 for half a second and then rev normally and shift. It's not consistent, sometimes it never does it, other times it will bog twice or three times in a row from stopping.
Here's what I know so far: The IAC is a new Borg Warner unit from a few months ago. It's got sufficient power and ground. The TP sensor is original. Checked VREF at 5 volts, SIGRTN at .9 - 1 volts and when unplugged, the sensor has a normal ohms sweep when you go from rest to WOT. I have just scrubbed the throttle body and reset the KAM so the computer could relearn if necessary.
There are no codes stored in the computer. Truck has around 184k miles and runs good aside from this issue. I'm stumped, I need suggestions on what to check next. I work for Ford and will have my fellow techs look too but I want to know what you guys think.
Man I don't really know, but I'd try getting it warmed up nicely and then shimming the throttle to where it's running at about 1200 rpm. Then pull the brake booster line and put some water into the brake booster until the engine starts to lug, then stop and let it recover. Run about three 32 oz big gulps of distilled water through it in this manner.
Expect lots of white smoke for a bit. Remove the shim and take her for about a 10 min drive. What you're effectively doing is steam cleaning the engine.
Don't know that this will help your problem, but it won't hurt.
I have had this exact problem on my 93 F150 351w. I replaced my emissions vacuum lines last week with new silicone rubber lines (I posted a thread on it about a week ago) because the original nylon lines had become brittle and starting to break. I have not driven enough since that job to be completely certain, but I think it might have corrected my hesitation problem.
I had an issue similar to that and it turned out the fuel pump was going out and not pumping enough fuel when I hit the throttle. That's the first thing I'd check. It could also possibly be the throttle sticking a bit and not properly opening.
That's actually a really good thought; I'd bet you might be onto something.
